Quantcast next project: SAS - Page 2 - Ford Truck Club Forum
Old January 31st, 2010, 03:32 PM
DIXIE FIX's Avatar
Images: 504
still waiting
Old February 4th, 2010, 06:38 PM
should have the first shipment in on Monday, that will include axle brackets and tube, 2nd will be on Tuesday, chassis brackets and shock tabs
Old February 4th, 2010, 10:31 PM
DIXIE FIX's Avatar
Images: 504
good...
i should have my axles and wheels by next week. at the latest end of next week.
Old February 8th, 2010, 07:16 PM
got the first box of parts in!!! another box should be here tomorrow!!
Old February 8th, 2010, 07:34 PM
Looks good!
Old February 8th, 2010, 10:18 PM
DIXIE FIX's Avatar
Images: 504
im likin it.
so you definitely settled on 4-link.
coil overs?
  #17
Old February 8th, 2010, 10:50 PM
yup!! probably gonna go with 2.5" Kings w/ remote reservoir
ordering the heims and tube adapters on Friday (payday!!!)
Old February 8th, 2010, 11:47 PM
Old Blue's Avatar
Old Blue Old Blue is offline
Images: 384
are you triangulating the front suspension??
Monthly Recognition Moderator
Check out my videos HERE
  #19
Old February 9th, 2010, 12:39 AM
DIXIE FIX's Avatar
Images: 504
from the looks of what he has setup, it doesnt look like it... does it?
Normally, lower link is mounted wide and low on the frame (subframe) and narrow and high on the axle. Then the upper links go from narrow and high to lower and wide on the axle...
ill get some pictures
heres a 4 link calculator
http://mysite.verizon.net/triaged/4l...tml/index.html
  #20
Old February 9th, 2010, 01:12 AM
DIXIE FIX's Avatar
Images: 504
got this info from another site:
"When building a truck, always use the center bellhousing bolt(or cam centerline) as your COG height. Its not really feasable to calculate the COG on a truck thats not finished, so this is a good starting point and is "close enough" to get you in the ballpark. It will also be consistant so you can base the trucks handling and any adjustments it may need from it.
Upper links should generally be 75% to 85% of the length of the lowers. Having shorter uppers helps maintain antisquat/ antidive #'s throughout the range of travel.This isnt an absolute, just a general rule of thumb.
Vertical seperation at the frame between the upper and lower links should be 70% to 85% of the vertical seperation at the axle( if you have 10" of vertical seperation at the axle, you should have 7"-8.5" at the frame). This is what affects the antisquat / antidive of the truck. Anything below a 50% anti squat/dive and you will have a truck that squats heavily on acceleration. Anything over 100% will cause the ass of the truck to raise under power. Anything between 50% and 100% is acceptable, but this comes down to personal preference more than anything.
You want to have your roll center as high as humanly possible. You also want a flat roll axis and I try to make the instant center as close to the other axle as I possibly can. Triangulation of the links play a huge roll in these numbers
If you are running mechanical steering, it definately has to have a panhard/ tracbar. If not you run the rish of having severe bump steer and possibly death wobble. I would run no more than 10* worth of triangulation in the links to eliminate the possibility of susp. bind, but the slight triangulation helps with the roll axis so it is needed. Whether you run 2 lowers with 1 or 2 uppers, or radius arms really depends on the design, intended use, and type of parts used in the build."
(View-All Members who have read this thread : 58
2Customs , 4x4x4 , 90f150xltcenturion , Agjake11 , AlgoridmJen , ASwaff400 , BigBlue79 , BigT67 , BigTrouble , bikertrash3531 , Booba5185 , brads93bronco , brick13 , bulldogginford , Burton7.3 , Buzzer , cblachly7808 , charnie , coca1 , CrazyD , DIXIE FIX , DoubleDee , dranger962000 , duke daddy , emedlijn , faulkenberrycameron , fbm1344t , firezapper , FORD TRUCK FAN , frank5079 , HellOnWheels , iamchadj , IrishKRO , jason77 , jasoncarpenter1 , Jendiump , jhollow10 , JRP , JSoko , Kickassguy , Klitch , knifeman , lilkix , mtdracing , nine5flareside , Pluto , Raleigh , Red91 , Russo2 , Sc4x4truck , Shanehib , skatebowd , The-LI-Redneck , WendyIcele , whitesleeper , xxpaintballxx , zachcollins1950 , zmr2010
New Project. hound_dogs_01 General Discussion
5 May 30th, 2010 10:44 AM
Project Gotham Show Car WebRidesTV WebRidesTV 0 March 21st, 2010 09:22 PM
Project Grandma...555 Part 2 EdelbrockTV EdelbrockTV 0 February 8th, 2010 04:52 PM
The Impala Project Two Guys Garage Two Guys Garage 0 January 29th, 2010 08:59 PM
HOT ROD TV: Project X Hot Rod Magazine Hot Rod TV 0 January 29th, 2010 08:59 PM
project , sas
