Quantcast 1960 Ford 4x4 - Page 2 - Ford Truck Club Forum
Old November 14th, 2013, 01:33 PM
carbineone's Avatar
carbineone carbineone is offline
Those codes and numbers were all on the tag on the glovebox door.. You have to use the corresponding top line with the bottom line of course..
They really did not have the same VIN numbers as they do on later vehicles. I do not believe VINs came along till about 30 years ago..So most decoders may just say there is not enough numbers in the search..
Maybe this will be easier.
WB
18
Color
B
Model
F103
Date
16F
Trans
FA
Axle
02
Well they could be Os or 0s
That serial number was on the same plate as the other info was..It says serial number. Not VIN number. Thanks
Old November 14th, 2013, 02:04 PM
back to either 1970 or 1983 they had 17 #'s
I found this
1959-60 Truck Vehicle Identification
Where To Find Your Vehicle Identification Number (VIN) For 1959-60 Ford the VIN plate is attached to the glove box. The information on the rating plate is the VIN number. The VIN number identifies the series, engine, model year, assembly plant and production sequence.
Vehicle Identification Number - F25J9U100001
Series Identification
F10 = F100
F11 = F100 4WD
F25 = F250
F26 = F250 4WD
F35 = F350
Engine Code
J = 223ci 6Cyl 1BC Carburetor 1959-60
C = 292ci 8Cyl 2BC Carburetor 158hp 1959-60
D = 292ci 8Cyl 2BC Carburetor 160 hp 1959-60
Models Year
9 = 1959
0 = 1960
Assembly Plant
A = Atlanta, GA
G = Chicago, IL
D = Dallas, TX
K = Kansas City, MO
L = Long Beach, CA
U = Louisville, KY
E = Mahwah, NJ
M = Memphis, TN
N = Norfolk,VA
S = Allen Park, MI
R = San Jose, CA
P = St. Paul, MN
I think the problem is for 1960 you need 12 #'s you only show 11
F10COK53782
Old November 14th, 2013, 02:09 PM
what i see is a 1960, F100 4wd, 292 V-8, made in Kansas City
there again there are some other members that can do this better than I, just wait
Old November 14th, 2013, 02:23 PM
carbineone's Avatar
Thanks, I believe that the engine is probably correct than.
I do believe it has been a 4x4 its whole life though. No way it was converted in my opinion. Maybe the one number I am missing is another 1 behind the F This is probably the number then F110COK53782
I probably missed a 1
You can just tell the body and frame have been together for all its life in my opinion.. And he has probably owned it since nearly new..Thanks
Old November 14th, 2013, 02:29 PM
found more
color A = Turquoise
model F103 = F100 5,600# 1/2T
Trans F = 4sp Warner T-98A
axle Rear 02 = 3.89-3.3M limited Slip
axle front A= 3.92 4x4
the trans code FA refers to F = trans type, A = front axle transfer case
Old November 14th, 2013, 02:31 PM
very well could be they did not show the 3 F10(3)COK53782
but the above is what I found about your NEW TRUCK
  #17
Old November 14th, 2013, 02:39 PM
Does your name 'carbineone' refer to a Ruger #1 carbine ?
  #18
Old November 14th, 2013, 02:44 PM
carbineone's Avatar
No, kinda close though..It is Firearms related of course.. I really like WWII M1 Carbines. Well really I collect all Military related..Thanks
  #19
if it's still got the 292 it will have a crossover tube about 2 inches in diameter from side to side above the front of the engine
  #20
Old November 14th, 2013, 02:45 PM
Originally Posted by carbineone View Post
No I really like M1 Carbines. Well really I collect all Military related..Thanks
didn't think about that one
my dad said when he was in Korea the M1 carbine would not penetrate all the winter clothing the Chinese wore
the M1 grand was a differant story
65custom , bikertrash3531 , Booba5185 , carbineone , ElGringo , glc , harrison28 , jonny99 , JSoko , supertrainguy , vinnyboy2409
installing 1993 f350 instrument cluster in a 1960 f100 willd 1948-1983 Ford F100
7 September 20th, 2012 12:56 PM
1960 F100 from Brazil vmazzoni New Member Introductions 17 July 11th, 2012 03:31 AM
Art Morrison 3G 1960 Corvette TheSmokingTire The Smoking Tire 0 October 4th, 2011 05:54 AM
1957-1960 Ford F-Series Trucks & Panels calinleir FORD F-100 | F-150 SERIES 0 December 19th, 2010 09:40 PM
1960 , 4x4 , ford
