Quantcast LED Question - Ford Truck Club Forum
Old November 12th, 2010, 03:38 PM
MR_Pete's Avatar
MR_Pete MR_Pete is offline
Images: 30
Liked 2 Times in 2 Posts
Default LED Question
As some of you know earlier this year I went through and changed out most of my standard lights with LED's. I've recently noticed that when I turn on all my main lights that the LED's I put in the lincence plate began to flash very rapidily when the truck is running. If I just turn on the lights, they look fine, but when the truck is running they almost appear to be strobe lights. I first noticed the left side bulb doing this, but now it has switched to the passenger side. I'm thinking it may be a ground issue, but am looking for ideas and suggestions too. I know a few of you have replaced many of your lights to LED, so let me know what may be happening. Thanks in advance!
04 FX4 Scab 5.4
God, Guns & Guts made America Free; Let's Fight to Keep all Three
I'm a supporting member
Old November 12th, 2010, 08:03 PM
pete59edsel's Avatar
Images: 101
Liked 6 Times in 6 Posts
I'm with ya on the ground issue...
Old November 13th, 2010, 06:47 PM
Hey Pete, sounds like you are in need of some LED resistors.
Old November 13th, 2010, 09:41 PM
MR_Pete's Avatar
Images: 30
I don't know, I installed these back in the early summer and all was ok for several months. Then one night I noticed the left side blinking and the right side ok, now it switched to the right side and it only does this when the truck is running. You can see the light flicker with the idle of the engine. It may be no big deal at all, but it is bugging me and I don't know if a cop would pull me over for this or not.
04 FX4 Scab 5.4
Old November 13th, 2010, 10:14 PM
Actually, it sounds like you will need some capacitors to correct your LED issue. The LED's are getting brighter with your trucks electrical current. By adding a capacitor before the LED, it takes the varying current and smooths it out.
You may want to look into this some more. Contact an LED website. Let us know the outcome please.
Old December 16th, 2010, 01:30 PM
did you find a solution MR Pete?
Old December 16th, 2010, 06:22 PM
MR_Pete's Avatar
Images: 30
No brother, I haven't. To be honest it isn't bothering me that bad. It will switch from side to side on which one blinks and sometimes they both do it. With all the time tied up hunting, a new job that demands way too much time and now these winter temps, I probably won't even fool with it till spring. Unless the law would pull me over and complain about it!
04 FX4 Scab 5.4
Old December 16th, 2010, 08:16 PM
when ever I have that type of problem on any of my trailers, it is usually the ground
good luck in the woods; seems as all the Deer disappeared around Thanksgiving
4x4x4 , cowboy , Dirtydog , JSoko , Kirt , marmaduke , martinleeo , MR_Pete , pete59edsel , RaviAuto , TedC , TPBull
EGR valve question... ASwaff400 1992-1996 Ford F150
1 September 21st, 2010 02:48 PM
Hello, and a pinging question. poopie 1997-2003 Ford F150
3 June 20th, 2010 11:44 PM
Gears question Agjake11 1997-2003 Ford F150
20 December 3rd, 2009 11:50 AM
QUestion LilBit 4x4 General Discussion
4 October 16th, 2009 10:59 PM
Next question please! BigT67 General Discussion
1 October 7th, 2009 02:31 AM
led , question
