Quantcast Ford recalls 2009-2010 F150 four door handle failure - Ford Truck Club Forum
Old February 5th, 2011, 07:00 AM
Default Ford recalls 2009-2010 F150 four door handle failure
The National Highway Traffic Safety Administration has announced a voluntary Ford recall of 2009 and 2010 F150 pickups due to weak return springs in the interior door handles which could allow the doors to open in the event of an accident.
The NHTSA does not state how many (but according to Ford - 280,000 units are affected) 2009 and 2010 Ford F150 pickups are affected by this door handle recall but this announcement pertains specifically to trucks built between January 18, 2008 and November 30, 2009. In select trucks built during that period of time, the return springs in the interior door handles may not be strong enough to pull the handle back into the fully closed position. In the event that a truck with the handle not “fully stowed” is in an accident, the spring could allow the handle to slip and the door could open.
In simpler terms, say that you open the driver’s door of your 2010 F150 to get out and when you close the door, the interior door handle does not return to the fully closed position. This means that once you get into the truck to drive next time, that handle could still be partially towards the open position and in the event of an accident, the impact could cause that handle to release and the door could fly open. This obvious greatly increases the likelihood of injury in an accident so Ford has gone ahead and made the call for those trucks to head back to the dealership. The announcement also states that there have been no injuries as a result of this defect.
This 2009-2010 Ford F150 recall is set to official begin on or around February 14th and Ford asks that any F150 owners with interior door handles that feel loose or do not seem to return to the fully stowed position contact your dealership right away. For those experiencing the looseness issue right now, the dealership will replace the door handle assembly but for those not currently experiencing the looseness issue, once the parts become available you will be asked to bring the truck to the dealership for inspection. Should the spring be found to be too weak, the spring will be replaced and in the worst situations, the handle assembly could be replaced. All of these services will be performed free of charge to the customer.
Old April 6th, 2011, 10:22 AM
Exclamation Recall - 2009-2010 f150
Ford is recalling 280,000 F150's because a failure in the door handle could cause the doors to open in a crash.
The recall affects 2009 and 2010 models built between Jan. 18, 2008, and Nov. 30, 2009.
a plastic piece of the interior door handle mechanism can become fatigued over time and reduce tension on the door handle spring. If this happens, the door could fail to latch.
For more information, F150 owners can contact Ford at 866-436-7332
original owners will recive a notice in the mail, others will have to read FTC
Old December 21st, 2011, 04:35 AM
cindyreinahart's Avatar
cindyreinahart cindyreinahart is offline
Thank you for the post. Lately, there were many automobile recalls. One of which was the Ford auto recall. Just a while ago, I also read an article connected with it albeit it was not the said car company. The post was entitled Nissan announces recall of Sentra and Juke. It stated there that recalls have been announced by Nissan for two different cars. The Sentra and the Juke are impacted by the recall, but the problems are not related.
In both recalls, Nissan is going to notify owners in January. In case of the Sentra, Nissan will replace the terminal and battery cover at no cost. Moreover, Nissan will also perform any necessary repairs on the Juke to correct the turbocharger issue.
Good thing car companies have consolations to its customers.
Old December 21st, 2011, 10:25 AM
somewhere on this site
you can find TSB's & re-call info for our Trucks
just can't seem to find it
by the way welcome to the site
Old December 24th, 2011, 10:22 PM
All Vehicle Safety Recalls and or Safety Notices and Bulletins must be must be registered with NHTSA or the National Highway Traffic Safety Administration. http://www.nhtsa.gov/.
This is not an option for the manufacturer it is MANDATORY and required by federal law.From http://www.nhtsa.gov/ you could start your search on the right side of the web site in the "REPORT A VEHICLE OR CHILD SEAT DEFECT"
~~ To do it the easy way follow the below ~~ To SEARCH Your Vehicle Click Here:
http://www-odi.nhtsa.dot.gov/recalls/recallsearch.cfm
The page is pretty much self explanitory -
1. Select by Type = Vehicle, Equipment i.e., and click on "Search Selected Type" or if you know the Campaign ID
2. Select Model Year and click on Submit Model Year
3. Select Make (i.e., FORD) and click on Submit Make
4. Select Model (i.e., F150) and click Submit Model
5. Select Component from scroll down menu if you want to choose a specific component - My advice is leave this alone so you get everything listed about the vehicle you are researching
6. Check the box if you do want to see a detailed report of the registered recalls and Click on Retrieve Recalls
Old December 25th, 2011, 09:34 AM
dont we have that option somewhere on this site ???
you know how to find TSB & Re-calls
this next remark is directed to the man behind the curtain "if not it needs to happen'
Old December 25th, 2011, 06:03 PM
On each page is Tech Archives - However, a "Quick Link to TSB Info" is not listed.
Is there is an Echo in the room? Someone with WiZaRd Powers could copy paste the below
To SEARCH Your Vehicle on the NHTSA Website - click here:
Old April 5th, 2012, 07:28 AM
shree12's Avatar
shree12 shree12 is offline
I am glad to see such information, which I was searching for a long time. This will really helpful. It's really very serious issue. I think, it's a great recall of ford.
Old April 6th, 2012, 12:16 AM
I whole heartly agree
(View-All Members who have read this thread : 22
BigBlue79 , Booba5185 , braxton , cindyreinahart , classiccarsaz , DoubleDee , ericspainter , HawaiianF150 , John Faczak , JSoko , Julin , Kevin Campbell , markscherz , michaelsnodgrass18 , nine5flareside , pete59edsel , Ridgerunner , Russo2 , Scotts Black FX4 , shree12 , willchase_19 , WORLDWITHIN@VERIZON.NET
How-To: Gotts Mod for 2009 / 2010 (w/ pics) ncTidalWave Garage Talk: Shop Class 101 13 December 1st, 2010 11:27 PM
How-To Remove Door Panels from a Ford Mustang MOTORZ TV MOTORZ TV 0 August 6th, 2010 06:23 AM
egr system failure? dcrouch557 1992-1996 Ford F150
3 July 14th, 2010 07:25 AM
CAI for 2009 F150 Bates88 2009-2014 Ford F150
129 March 22nd, 2010 01:16 PM
Ford ESCAPE Recalls BigT67 General Discussion
0 July 2nd, 2009 02:18 PM
door , f150 , failure , ford , handle , recall , recalls
