Quantcast door ajar? - Ford Truck Club Forum
Old July 7th, 2011, 12:51 AM
975.4's Avatar
975.4 975.4 is offline
Default door ajar?
for some reason when it gets hot out my interior and door ajar light stay on. im not even sure where to start. i know my doors are closed so thats not a problem. it may be from water damage. the rear window slider had a crack in the assembly piece or what ever it was a recall. any help would be appriecated.
Found
On
Road
Dominating
Old July 7th, 2011, 01:35 AM
DoubleDee's Avatar
Images: 669
The actual door latch mechanism in the door. I had the same problem with the stRanger. The switch is co-located with the latch, and spritzing it with WD-40 will solve the problem. Squirt, squirt, and squirt a little more, then open and close a few times to "work" the swich. Seems like the years 97-03 F150's and Rangers had this problem. Try it out and report back!
And no, it's just a door.
Or maybe an access panel, but ajar it is not!
A hinged access panel...
Double(. Y .)Dee
SSG, TXARNG
How To Use The FTC Gallery
VIN Decoder
Big 3 Upgrade
Seat Removal
Interior Trim/Carpet Removal
Old July 7th, 2011, 06:37 AM
also the expeditions have that problem, my rear passenger door does that every now and then
Old July 7th, 2011, 07:50 PM
Stewy 39's Avatar
Stewy 39 Stewy 39 is offline
Images: 12
The wife's expy does this too but only when it's freezing out. Like double dee said-squirt squirt!
Old July 7th, 2011, 09:25 PM
whitesleeper's Avatar
Default the light
ok gents door ajar
gue gets stuck on the stem that sticks out of the switch ....
YES as was said my DoubleDee a little shot of spray will do it ....
All fords from 1997 to current use the same damn switch ....
i have found that on a day you have NOTHING better to do remove the switck clean it and lube it with white lithium grease should last for years ....
have a nice evening GENTS
Old July 8th, 2011, 12:25 AM
975.4's Avatar
IT WORKED!! YAY!!! thanks guys. this has been buggin the heck out of me for the longest time! its a good weight of my shoulders i thought i was going to have to pay big bucks to fix it. its just weird it only does it when its really hot out. i would think it would be worse in the winter.
Found
On
Road
Dominating
Old July 8th, 2011, 02:23 AM
Pretty nice when a little lube does the trick isn't it?
Old July 11th, 2011, 12:12 AM
975.4's Avatar
its the best lol
Found
On
Road
Dominating
Old July 11th, 2011, 11:28 AM
just sprayed some PB blaster in the latches, it worked! lol
975.4 , ASwaff400 , BigT67 , DoubleDee , Gdcotton , HawaiianF150 , JSoko , Klitch , nine5flareside , Russo2 , skatebowd , Stewy 39 , Terry G. , TheAmplified42 , volvering , whitesleeper , Willows Wind , wishmaster767
need iterior door panels cootersbigblackford Auto Parts Wanted
10 February 16th, 2011 09:31 PM
How-To Remove Door Panels from a Ford Mustang MOTORZ TV MOTORZ TV 0 August 6th, 2010 06:23 AM
2003 expedition door ajar alert chatterjj Ford Expedition 6 March 14th, 2010 02:45 AM
Door panel painting! For the win. b2therad 1997-2003 Ford F150
16 January 28th, 2010 11:31 PM
Door Switch LED swap Agjake11 Garage Talk: Shop Class 101 3 December 13th, 2009 04:13 PM
ajar , door
