Quantcast carburetor installiation, and issues - Page 2 - Ford Truck Club Forum
Ford Truck Club Forum > FORD BRONCO | BRONCO II > 1980-1986 Ford Bronco
  #11
Old July 11th, 2011, 03:58 PM
Originally Posted by tjdinmaine View Post
well i have an old choke cable that works, ive just been staring at the damn carb trying to figure out what needs to come off and how; and where exactlly to attach the cable. if anyone has one of these damn halfbreed carbs that has switched to a manual choke, could you put up a picture?.
spend $10 on the kit, it come with the cable connectors and bracket with nuts&bolts and a diagram
that shows you whats gotta come out of the old electric choke
  #12
Old July 12th, 2011, 08:45 AM
tjdinmaine's Avatar
tjdinmaine tjdinmaine is offline
10-4!!
  #13
Old July 12th, 2011, 08:59 PM
tjdinmaine's Avatar
well bought the choke cable. drilled out the rivets on the old choke got it all in there and hooked up, and it seemed to run great, until i noticed that fuel was spraying EVERYWHERES..Shit, there was a small kink in the fuel line, and it cracked apperantly in hooking it back up. so next job, replace the metal line from the mechanical pump. and probablly the pump while im at it since its only 30 bucks.. ahh the joys of junk lol
  #14
Old July 12th, 2011, 10:52 PM
PS: check that choke setting to make sure it stays open (viabration = loose screws)
and it will take some getting used to in cold weather to get it to crank & stay ideling
if you've used a manual choke before you know what I mean
and dont forget to push it all the way in once your down the road
(View-All Members who have read this thread : 14
975.4 , ASwaff400 , BigBlue79 , DoubleDee , dsb12 , icepicker , JSoko , nine5flareside , pete59edsel , Russo2 , Thomasstemmle , tjdinmaine , tmace , vjsimone
Electronic 4wd Issues herbz 2004-2008 Ford F150
26 May 26th, 2013 12:16 AM
Front Tank issues tity04 1992-1996 Ford F150
15 December 4th, 2011 09:48 PM
Gas gauge issues nismo972 2004-2008 Ford F150
3 July 10th, 2010 09:39 PM
4x4 Issues - 97 Klitch 1997-2003 Ford F150
33 January 3rd, 2010 02:57 PM
Frozen carburetor BigT67 General Discussion
0 December 19th, 2009 11:15 PM
4.9 , bronco , carb , carburetor , installiation , issues , vacuum
