Quantcast 92 Ford f150 5.0 302 rough idle and squealing even when serpintine belts off - Ford Truck Club Forum
Old July 28th, 2018, 12:31 PM
Herbie's Avatar
Herbie Herbie is offline
Default 92 Ford f150 5.0 302 rough idle and squealing even when serpintine belts off
My truck just started squealing a very high pitch sound from engine. It has a new serpentine belt and pulleys are good. Here's were it gets crazy....took belt and ran the motor and still it squeals...it also dies while in idle...does anyone know whats going on?
Old July 30th, 2018, 08:47 AM
Without a belt, the only things moving are the cam, crank, and the distributor. Can you tell if it's coming from the front or the back of the engine? Have you changed the oil since this has started happening? Notice any bearing material in the old oil?
Old March 7th, 2019, 01:44 PM
Herbie's Avatar
It sound like its from the front of the vehicle...no oil change since it started...the squealing stopped, but it still dies when at idle, also the truck jerks randomly after I drive it for a 10 minutes
Old March 7th, 2019, 02:51 PM
Liked 113 Times in 109 Posts
Dying at idle can be a sticky idle air control valve. Jerking randomly could be misfires, which would be spark plugs, plug wires, cap, and rotor. All this can possibly be a bad MAP sensor. The squealing could be the harmonic balancer.
Old April 19th, 2019, 06:42 PM
jheat's Avatar
jheat jheat is offline
This could also be the throttle position sensor. Is the check engine light on?
92 F150 XLT 2WD 5.0 302 E4OD long bed
glc , harrison28 , Herbie , jheat , JSoko , Ken , TorqueO , vjsimone
Fast Idle problems on '88 F150/302 1victoryrider 1973-1991 Ford F150
1 January 6th, 2018 11:02 AM
slugish/no power/rough idle/bad gas millage judd94 1973-1991 Ford F150
4 January 14th, 2016 10:00 PM
5.4L 3V with miss, rough idle and codes P0340, P0344, P0345, and P0349 lindboep 2004-2008 Ford F150
8 August 18th, 2014 07:09 PM
Rough Idle, No power, black smoke??? adoporto 1992-1996 Ford F150
17 January 13th, 2014 11:41 PM
16 August 26th, 2012 10:44 AM
302 , belts , f150 , ford , idle , rough , serpintine , squealing
