Quantcast 1988 F150 Instrument Cluster Question - Ford Truck Club Forum
Old January 12th, 2012, 12:16 AM
Exclamation 1988 F150 Instrument Cluster Question
My new to me 88 has the standard instrument cluster(no tach) how hard is it to swap in the one with the tachometer? I'd like to see what this thing is revving up to when shifting but don't wanna wire in an aftermarket.
Old January 12th, 2012, 12:39 AM
Should be a direct swap.
I will have to check back through my internet finds from before, but iirc, it should just plug in and be all there.
Have to set the mileage though, I would get out a drill and go to the end of the speedo cable from the transfercase and have fun ha
Old January 12th, 2012, 12:42 AM
why would he "Have to set the mileage" ???
if he wants a tach
Old January 12th, 2012, 12:43 AM
I can verify it is plug and play. Might want to upgrade the oil pressure switch to a sender and modify the new (with tach) cluster while it's out...I can elaborate if you want me to. It basically makes the oil pressure switch worth something, and not just an idiot light.
Old January 12th, 2012, 12:45 AM
The 2 gauge clusters do not have an interchangeable speedometer, so the mileage would have to be reset on the new speedometer if he wants it to be correct.
Old January 12th, 2012, 12:51 AM
Let me get this right, I can swap the two, without having to change the wiring and all I have to do(if I want my mileage to be correct) is to match the mileage on the new one?
This cluster in it now has an oil pressure gauge, I thought they all did.
Old January 12th, 2012, 12:58 AM
Precisely ken, plug and play.
The stock oil pressure is just a 6psi switch, motor gets 6psi, it reads somewhere in normal on the gauge.
Cross a diode or something like that on the switch and get a pre efi sender and it will sweep like a real gauge, without numbers.
Best part about the mileage is, it's super easy to change. And since there is no hundred thousand spot, it won't take long.
Old January 12th, 2012, 01:00 AM
Yes you can swap the cluster right in.
No, you don't have an oil pressure gauge, it's a glorified idiot light. It'd hooked up to oil pressure switch on the block, and once oil pressure hits at least 6 PSI, a 12 volt signal is produced. On the rear of the cluster is a resistor to reduce the voltage to about 5 volts. The gauge would typically peg all the way over to the right with a 12v signal, so this resister makes it "appear" to have an oil pressure gauge.
The modification is to use a bell-type oil pressure sender from a pre-87 truck that actually produces a varying voltage, based on oil pressure. It's a direct swap (the plumbing included), and then you have to bypass the resistor on the back of the cluster.
Old January 12th, 2012, 01:06 AM
That's something I can't do yet, so it'll wait, I'm going to see about getting a cluster from the pull a part later this week, early next week and match up my mileage then swap'er in.
Thanks for the help guys!
If you could booba, post up how to bypass that resistor and I'll get to it later on down the road, thanks again for the help!
Old January 12th, 2012, 01:09 AM
While your at a Pick n pull look for the oil pressure sender, thats where I got mine, and they gave it to me (free). I'll go grab ya some pics...
90f150xltcenturion , BigBlue79 , Booba5185 , Hhaley0991 , JSoko , mylife69 , Russo2 , scbill , Scorekeeper58 , stro , willd , windigowolf
1995 f150 Instrument Cluster Mod - TEASER nine5flareside 1992-1996 Ford F150
5 January 30th, 2012 11:10 AM
95 instrument cluster swap = alternator not charging nightshade 1992-1996 Ford F150
6 January 27th, 2012 08:59 AM
Lightning Instrument Cluster Swap The Frankster 1992-1996 Ford F150
1 January 27th, 2012 08:54 AM
1980-1986 Instrument Cluster w/ tach BigBlue79 1980-1986 Ford Bronco
0 September 17th, 2011 06:17 PM
How To Center Shift Pointer Needle In F150 Instrument Cluster DIXIE FIX Garage Talk: Shop Class 101 5 November 28th, 2009 05:42 PM
1988 , cluster , f150 , instrument , question
