Quantcast Steering wheel way off center.. HELP! - Ford Truck Club Forum
Old November 16th, 2012, 07:11 PM
charnie's Avatar
charnie charnie is offline
Images: 4
Liked 2 Times in 2 Posts
Default Steering wheel way off center.. HELP!
My steering wheel is way off centre but the she drives straight and doesn't pull to the left or right. I did a wheel alignment after I did the front end swap. but the wheel is still off. Guys have told me theres a blot that will re just the wheel. if so where can i find it ?? any help with this one would be great.
Old November 17th, 2012, 07:24 PM
Unless the wheel is a full 180* off center then the only thing you can do to put it back to center is an alignment. There is plenty of adjustment in the steering linkage to fix this issue. I would go to a different shop.
Old November 18th, 2012, 08:12 PM
charnie's Avatar
Images: 4
If one was to do this them self, what adjustment should I try first to the steering linkage?? I know what a green question.. hahah its learn as i go.
Old November 18th, 2012, 10:03 PM
I wouldn't do it yourself.. but there are sleeves on the tie rod ends, you adjust those and it brings the tires a certain way and the steering wheel a certain way. I wouldn't do it myself except to get it close after axle work before the pros get to it.
Old November 18th, 2012, 10:05 PM
can't you pull the wheel & re position it ?
Old November 19th, 2012, 12:09 AM
It only goes on one way. Granted you could pull the wheel and force it on the splines any way you please, but that's not safe or correct.
Old November 19th, 2012, 02:21 AM
charnie's Avatar
Images: 4
Good to know..Thanks! Ill take it into a shop and get them to do it...
Old November 20th, 2012, 12:19 AM
I would go find a shop, ask them if they can get it done, then allow them to do the work. Don't just drop it off and expect it fixed, make them aware of the issue and what you specifically want done.
Old November 20th, 2012, 01:33 AM
charnie's Avatar
Images: 4
Found a good shop today! Talked to the guy and told him the whole story! Russo your right you shouldn’t pull the wheel & re position it. Really unsafe and causes more wear, but you can. The shop I found is going to let me hang out and learn a thing or two...don't find that every day :) Give ya up date when it’s done
Russo2 (November 20th, 2012)
Old November 22nd, 2012, 10:27 AM
good to know about the repositoning
90f150xltcenturion , ASwaff400 , BigBlue79 , Booba5185 , catmechanic07 , charnie , jones03100 , JSoko , rikard , Russo2 , The Frankster
Steering wheel MOD TFH Kane 1997-2003 Ford F150
2 March 21st, 2012 09:29 AM
Truck U: Steering Wheel Oscillation TRUCK U TRUCK U 0 May 5th, 2010 11:41 AM
steering wheel swap? ASwaff400 1992-1996 Ford F150
2 January 10th, 2010 11:02 PM
Information Center display not working SS FatMan 2004-2008 Ford F150
20 September 4th, 2009 10:39 PM
center , slightly , steering , wheel
