Quantcast Reaper1 - 84 f-250 custom build - Ford Truck Club Forum
Old July 7th, 2013, 04:30 PM
CoCrawler's Avatar
CoCrawler CoCrawler is offline
Default Reaper1 - 84 f-250 custom build
So I have come to the conclusion that the 84 F-250 plow truck that has been sitting for the last 3 years is going to be transformed into my back country Elk recovery vehicle.
As it sits now it is a reg cab ¾ ton pickup. The plan is to extend the reg cab to either a Crew Cab or Extended Cab ( I know the crew cab was on the f-350's). First choice is the 4 door as long as we don’t have to stretch the frame. We will also do a 2 – 4 inch lift and bigger tires. Don’t want it too high. The stock bed will be removed and replaced with a utility bed. Side compartments will also be refrigerated and room for all the necessities to support a back country hunt/outing.
the design is based on the RESQ1 07 jeep build. Figured I would use the vehicle I had sitting around instead of buying something else.
here are some very rough sketches of what I am attempting.
ID:	933   Click image for larger version
Old July 7th, 2013, 04:38 PM
CoCrawler's Avatar
the first order of business is to take care of the front axel. it seems that the passenger side u joints have blown apart. as near as I can tell these are Dana 44 hd axel's? when I looked at this the other day it also appeared that there was another set of u-joint up by the housing.
so the first question is should I just replace the broken ends or buy a complete new front end?
for this build I was looking at a 4 inch lift and not sure what size tires. not looking to build a monster truck just something with a little ground clearance. recommendations?
ID:	935   Click image for larger version
Name:	pass axel2.JPG
Old July 7th, 2013, 08:52 PM
good ide and I like the name
long time southeast bowhunter here
CoCrawler , glc , harrison28 , JSoko , Tr00b , TwoStroke
302 Build BigBlue79 Garage Talk: Engine & Drivetrain 133 October 14th, 2013 11:35 PM
My '73 F-100 4x4 Custom 1977 F-250 4x4 Custom 1948-1983 Ford F100
32 August 11th, 2012 10:48 AM
1979 F150 Custom build thread BigBlue79 1973-1991 Ford F150
7 March 9th, 2012 10:21 PM
Custom Hot-Rod GTX [S2 Ep.6-3] Gearz Gearz 0 February 3rd, 2011 07:46 PM
My Custom 150 Josiah New Member Introductions 14 December 5th, 2009 05:18 PM
build , custom , f250 , reaper1
