Quantcast Trailer wiring problem - Page 4 - Ford Truck Club Forum
Ford Truck Club Forum > GARAGE TALK > Garage Talk: Towing & Hauling
  #31
Old July 28th, 2010, 02:17 PM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 262
the green wire in that picture was added later to the outside of the original bundle and is serving as ground. The second and third pictures are each end of the plug that I cut off and replaced with a flat 4.
Big T
  #32
Old August 4th, 2010, 10:37 PM
BigT67's Avatar
Images: 262
OK, finally got the basics to work! Referring back to the pictures I posted on the last page, specifically the top one, the blue, black and red wires are not being used. I spliced on a flat 4 plug using the brown (right turn/brake), yellow (tail lights), orange (left turn/ brake), & green (ground). Also, I had the wheel bearings replaced and had to replace a rim that wasn't the right size and wore out the studs (which also had to be replaced!).
Big T
  #33
Old August 4th, 2010, 10:45 PM
One small step for man... one giant leap for man kind!
  #34
Old August 4th, 2010, 11:49 PM
= a slight stumble for Big T!
BATES
Banks & PHP Powered
  #35
Old August 5th, 2010, 08:19 AM
Hay BigT, good call on the bearings, I'm surprised I did'nt mention that, as that and proper tire inflation is a subject that I run into the ground around here.
Good Luck and enjoy your time away from Home
  #36
Old January 31st, 2011, 04:21 PM
Bathexpert's Avatar
Bathexpert Bathexpert is offline
some may have seperate break and turn my 91 cutaway has them and had to wire with the addtaper. But your problem was with the running lights as I read through this and that would not be a problem here. check for a good ground can not depend on the hitch to transfer through also check blubs with a battery to see that they are good.
Bathexpert , Fordtruckman88 , gvfc2 , JSoko , Klitch , mschoppe67 , tjdinmaine
Trailer hitches nismo972 Garage Talk: Towing & Hauling 3 March 21st, 2010 11:09 PM
Truck U Custom TJ Trailer TRUCK U TRUCK U 0 February 1st, 2010 12:12 AM
Super Wiring Two Guys Garage Two Guys Garage 0 January 29th, 2010 08:59 PM
problem , trailer , wiring
