Quantcast 94 Ford Ranger XLT won't stay running :krying: - Page 3 - Ford Truck Club Forum
Old August 1st, 2010, 08:30 AM
so this 'chip' can be held in your hand
as opposed to a 'SuperChip' which is a hand held tuner and tune info is downloaded via a cable, that is later disconnected; thus nothing you can physically remove.
Jarhizzy, where you from???
  #22
Old August 1st, 2010, 09:57 AM
the chip plugs into the pcm and stays ther till you want to remove it...
pre-obd2, no hand held tuner.
Old August 1st, 2010, 10:01 AM
Jarhizzy's Avatar
Jarhizzy Jarhizzy is offline
Images: 8
thanks aswaff. I was only one step away. Also sorry for not uploading to FTC. I will from now on. I will go ahead and post back within the next two hours to let ya know what I find. IF the guy lied and no proformance chip was installed will there be anything thing there?
also jsoko I am from Pittsburgh, PA.
  #24
Old August 1st, 2010, 10:08 AM
if there is no chip, there will be a small plastic cap, or nothing at all
Old August 1st, 2010, 11:21 AM
Joey, pre 1996 Cars and trucks had OBD I units. 96 and new (such as your 150) have OBD II systems. The hand held tuners only work on OBD II systems... I would love to have one for my 150 but I am stuck with a chip.
  #26
Old August 1st, 2010, 11:43 AM
Jarhizzy's Avatar
Images: 8
well i went out and continued where i stopped yesturday. I found out that I do have a chip.
<img src="http://www.fordtruckclub.net/forum/photopost/files/5/3/0/chip.jpg" alt="Hypertech 4.0l Proformance Chip" />
I read up on it. This is all it says :
"Part #640721, 1994 Ranger 4.0 Manual Transmission
•Premium Octane "
Not sure If i would put money out for this but since i got it included i guess it is a bonus.
  #27
Old August 2nd, 2010, 09:47 AM
Another Pittsburgh guy! nice
Have you tried removing that chip to see if maybe there's something going on with it? I'm not too familiar with those types of chips....but I wouldn't imagine it would hurt anything to just remove it to see.
  #28
Old August 2nd, 2010, 11:52 AM
"premium octane" kinda clues me in that its a 'performance chip'
even though you did'nt know that, if your not useing 91 or better I suggest you start
it has something to do with them pistons going up and down
and that computer being fooled by that 'chip'
on that trans. leak; there should be an access plate or plug so you can see the flywheel
just behind where the leak is, see if you can look in there with a flashlite you may not see the point of origin but if fluid is slung around everywhere could be it's on the clutch also
on that manual trans. I would suspect a leaking front seal
  #29
Old August 2nd, 2010, 03:26 PM
Jarhizzy's Avatar
Images: 8
Glade to not be here alone.
jsoko: Are you talking about the fill plug? Look threw the fill plug? I was putting in 89 because that is what the guy was running. From now on ill run 91. The truck is good on gas so Im not worried about putting the extra cash out for it. Now if I had to put 91 in my 75' caddy....different story.
I planed on pulling the trans out anyway because i felt the clutch slipping so to fix the seal or the clutch, it has to come out.
My other problem:
Front diff is leaking oil pretty bad. I noticed a puddle after i parked it and i sall it stop dripping. figured it was all out. popped open the fill plug and it was bone dry. so i cleaned up the area and added some to see if I can make sure it is the diff instead of a seal by the axle(because I noticed oil there too). I placed a little over a quart in an not even 1 hour later it was all out. I know how to change the seal on the rear diff and I assume it is the same. But one problem, On the front end of it(facing the front of the truck) is the screws and it seems to be all connected. Unlike the back diff, just a single plate. The front goes the whole width of the truck. Not sure what I have to do to take it off but i think theres alot to do. Ill get a picture up to show you what I mean.
Thanks Everybody for the help!
Update:
Pictures are from Cell, sorry for quality.
Front Diff Whole:
<img src="http://www.fordtruckclub.net/forum/photopost/files/5/3/0/front_diff.jpg" alt="1994 Ford Ranger 4.0l 4x4 Front Diff" />
Front Passenger Side Diff Bracket:
<img src="http://www.fordtruckclub.net/forum/photopost/files/5/3/0/front_passenger_side_bracket_for_diff.jpg" alt="1994 Ford Ranger 4.0l 4x4 Front Passenger Side Diff. Bracket" />
Front Driver Side Diff Bracket?:
<img src="http://www.fordtruckclub.net/forum/photopost/files/5/3/0/front_driver_side_diff_bracket.jpg" alt="1994 Ford Ranger 4.0l 4x4 Front Driver Side Diff. Bracket" />
Picture of Red gasket On backside of Diff. Look towards the center left and you will see it:
<img src="http://www.fordtruckclub.net/forum/photopost/files/5/3/0/back_side_of_diff_gasket_shown.jpg" alt="1994 Ford Ranger 4.0l 4x4 Bad Front Diff. Gasket" />
  #30
Old August 3rd, 2010, 11:58 AM
Jarhizzy's Avatar
Images: 8
Any suggestions on how I should go about changing the gasket on the front diff?
F150GT , knifeman , nine5flareside , Patch87 , rfraze , WORLDWITHIN@VERIZON.NET
Is your computer running? BigT67 General Discussion
1 November 13th, 2011 09:25 PM
Spied! Next Gen Ford Ranger Bates88 Garage Talk: General Tech Talk 0 June 12th, 2010 03:56 PM
ESP is running out, need suggestions..... 2004FX4F150 2004-2008 Ford F150
10 March 13th, 2010 01:21 AM
Ex-Nebraska running back convicted of murder BigT67 General Discussion
0 August 25th, 2009 12:07 AM
Running Overhead MBE 4000 style catmechanic07 Garage Talk: Paint & Detailing 2 July 17th, 2009 01:26 AM
ford , krying , ranger , running , stay , truck , xlt
