Quantcast My codes 172,175,1137,1157 - Ford Truck Club Forum
Old September 9th, 2010, 01:41 AM
Default My codes 172,175,1137,1157
I'll give a brief history, I'm the unhelped step child on other forums and I'm not sure why.
put together a 5.4L lightning engine with port and polish heads and swapped it for the 4.6, and went with the rest of the sheep at the time to "Troyer Performance" for tuning. The truck has NEVER run correctly, though when its cold and hasn't had a chance to change loop it runs its best (almost perfect). I insist its all tuning, Troyer just shook his finger at me and said in a nutshell it was mechanical and my fault. His reasoning is my MAF is clocking ~250 AD counts on his program, and I think that was appx 1.25-1.5v at idle.
<hr>
Fast forward to last week (3 yrs later)
My vacation with the camper set these codes at different intervals (camper battery dead celled and ate my batt down)
P0401 (I have egr blocked off, I expect this)
P0172 System Too Rich (Bank 1)
P0175 System Too Rich (Bank 2)
P1137 Lack Of HO2S12 Switch - Sensor Indicates Lean
P1157 Lack Of HO2S22 Switch - Sensor Indicates Lean
Wideband actions:
idle 14.5-15.8 AF/r
very minimal throttle, flat ground, closest to no load I can possibly get 14.5-15
minimal to moderate throttle on a good day (rare occurrence) 11-12.
anything else pegs the gauge rich.
Has a rolling idle when warmed up and in gear, does stall intermittently but only when building speed, if I creep 1-3mph the truck idles fine.
I'm confused now, how can I get conflicting codes like that on the same trip?
Old September 9th, 2010, 09:18 PM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 262
Maybe the codes were set off at different times (different temperature, driving conditions, fuel source?, etc) unfortunately that's about all the help I can offer at this point.
Big T
Old September 10th, 2010, 01:54 AM
Hmm, well the codes were read at my 2nd gas stop, they had been lit for 10 mins before I checked. Still though, I'm sure you understand how I'm confused.
Old September 10th, 2010, 11:11 AM
BigT67's Avatar
Images: 262
yes, I can see where the confusion comes from, but consider this, perhaps the rich codes were thrown during coasting or idle and the lean codes during acceleration? and if it was shortly before a fuel stop, maybe your fuel filter is in need of changing?
Big T
Old September 10th, 2010, 05:15 PM
pete59edsel's Avatar
Images: 101
Liked 6 Times in 6 Posts
How about the infamous vac. leak?
Old September 10th, 2010, 08:36 PM
I have always had 15" of vacuum at idle, I was told the cams I chose was probably the main culprit, but I am not sure of either of those issues (cam or vac leak) but haven't found a leak yet.
perhaps vice versa (wideband screams rich whenever I give it gas), fuel filter was new 3 years ago and a grand total of 5k miles.
I did however get pointed to a source that says the 1137/1157 codes are set by the downstream sensors. so upstreams flag right, downstreams flag lean. Widebands all over and usually rich, I guess I should buck up and buy $100 worth of motorcraft o2's upstreams.
Old September 11th, 2010, 02:53 PM
http://scottykilmer.homestead.com/~s...H_H=1752653345
Old September 11th, 2010, 08:42 PM
Old September 12th, 2010, 05:57 AM
chalk one up for the 'old salt'
modifying the emissions and injection system like you have takes all bets off. Your computer is set up for a stock system, which yours no longer is. So you can get the computer saying it's too lean AND too rich. The computer can try to compensate for lean, and cause too rich, and vice versa. This is one reason I NEVER advise anyone to modify that stuff on a street vehicle. Racing is one thing, but driving on the street is another. Unless you can find a ford computer genius to reprogram yours to run correctly, it never will. I see this all the time with mods,so I never advise anyone to do it. The good old days of hot rodding engines is LONG gone. Good Luck, hope you can find someone who knows how to reprogram things. Scotty
Old September 12th, 2010, 01:28 PM
Joey
We were all hoping a new ECM for the 5.4 tuned to the new changes and other addon's wasn't the answer.
Alas - the old addage still applies -
When you change or alter anything from design; there is loads of homework.
Klitch-
All may not be lost. Scotty knows best here. But perhaps a look see in Ford's Technical Manuals might reveal sensor part numbers with its ranges. Use the range values to correspond to the changes you made in the 5.4L.
Also check out the manufacturer of the parts you put in. They should have design specs that keep them from being sued. Might be propietary but wont know until you ask them.
Gonna be lots of research homework but cheapest way to go. Hopefully you havent changed the Cam and Crankshaft ranges too far out of stock limits.
DoubleDee , Moore1991bronco
1137 , 1157 , 172 , 175 , codes
