January 24th, 2012, 08:39 PM
Ranger 4cyl. Extra spark plugs
MY HAYNES REPAIR MANUAL ON MY 1994 RANGER 2.3L 4CYL. IS VERY WEAK ON ANY WHY QUESTIONS. PARTICULARLY, WHY THE 8 SPARKS ? THE 4 PLUGS ON THE LEFT ENGINE SIDE ARE THE MAIN ONES. THE ENGINE WILL RUN ON JUST THOSE 4 AND THE EXHAUST SIDE PLUGS NOT FUNCTIONING.
BUT, IT RUNS ROUGH. I 1ST ASSUMED THAT THE EXHAUST SIDE PLUGS WERE JUST FOR EMISSIONS. NOW, I DONT KNOW ? I ALSO ASSUMED THAT THESE 2ND 4 PLUGS FIRED AT A DIFFERENT TIME THAN THE MAIN 4 PLUGS. ( PROBABLY LATER ). I ALSO ASSUMED THAT THEY FIRED LATER TO PREVENT DETONATION/ KNOCK. BUT, I READ IN AN OLD SPORTS ENGINE DESIGN BOOK THAT ETHANOL IN GAS TENDED TO PREVENT DETONATION.
SO, NOW I'M BACK AT SQ. ONE. MY ASSUMPTIONS MAY BE WRONG. DOES ANYONE KNOW THE WHY BEHIND THE ENGINE DESIGN ABOUT THE 8 SPARK PLUGS ? APPRECIATE ANY INFO. ----- jim
January 24th, 2012, 09:17 PM
From what I've seen and read here and there, the 2nd set of plugs were to help with power, fuel economy and emissions. It might have helped prevent detonation as well.
Double(. Y .)Dee
SSG, TXARNG
January 24th, 2012, 11:23 PM
i thought of something else. ranger 2.3l are supposed to be best-in-class for gas mileage.and they seem to have the most torque,in class. so, maybe, the extra 4 plugs are there to burn any left-over gas molecules to give the best possible gas mileage. ??? just an idea.
does anyone know about other car/truck makes/models that have 2 plugs per cylinder ?
January 24th, 2012, 11:26 PM
thank you, Double Dee,
January 25th, 2012, 08:50 AM
the extra 4 plugs were for burning any additional exhaust gasses on the exhaust stroke
it was know as 'fart exhaust'
January 25th, 2012, 09:03 PM
Pretty sure its all emissions, my dads 89 has same setup.
January 25th, 2012, 10:07 PM
January 25th, 2012, 11:34 PM
O.k. I still have some lingering questions about extra sparks (and extra farts ) . I did a test-by removing the extra 4 plugs. Then started the truck and to my surprise the truck ran very rough. Which made me think that they were contributing to the power stroke.
If the spark occurs in the middle of the exhaust stroke it would clean up emissions (farts ) but it would resist the pistons travel upward. So, they make make it occur at end of downward power stroke- to give it some more power and also finish off unburned fuel before piston starts upward for exhaust. I thought when i made my remove test that there would be no big engine change. I thought just emissions change. I thought the engine might run even better without extra plugs. But, i was wrong and now im doomed to be fascinated by the design until i really understand it and its design motives. I .also, think that it has something to do with the rangers good gas mileage (2.3l anyway) and its great torque feeling. I could start on the level in 4th gear. Also, another question comes up- why did they not do 2 plugs per cyl on the v-6 ? Also, klitch, might i ask was the 89 a 2.3l not a v-6. And also , i wonder did any usa make or other jananese or euro brand ever go 2 sparks per cylinder. ----------- life,so many questions, so lttle answers
January 26th, 2012, 07:41 PM
the only other one I can think of is the late model Dodge Hemi's
they have 16 plugs
January 26th, 2012, 08:21 PM
... Ok my problem with your statement is you wrote you removed the extra plugs... Ya, actually removing the plugs then noting it runs rough? OR do you mean you unplugged the coil pack?
The 89 is a 4 banger, my brother has a 4 banging gerbil machine with the 5spd and 5.13's turning 35s.
We do have the 4.0 v6 in a 91, I have the 2.8 v6 in a 85 B2, never touched it yet.
Thread Tools |
Display Modes |
Linear Mode
(View-All)
Members who have read this thread : 16
ASwaff400
BigBlue79
BigT67
bikertrash3531
Booba5185
catmechanic07
DoubleDee
F150GT
herbz
JSoko
Klitch
nine5flareside
pwallace67
Ridgerunner
Russo2
WORLDWITHIN@VERIZON.NET
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Reading Spark Plugs
BigBlue79 |
Garage Talk: Shop Class 101 |
12 |
March 31st, 2012 08:39 AM |
Spark Plugs 5.8L
BigBlue79 |
1980-1986 Ford Bronco
11 |
November 1st, 2011 06:21 PM |
New spark plugs
screwon23s |
1997-2003 Ford F150
10 |
July 31st, 2011 08:48 PM |
E3 Spark Plugs
Gearz |
Gearz |
0 |
March 23rd, 2011 04:11 PM |
Which Spark Plugs?
2004FX4F150 |
2004-2008 Ford F150
4 |
December 11th, 2009 09:14 PM |
