Quantcast 1993 Ranger ?'s...... - Ford Truck Club Forum
Old January 26th, 2013, 07:37 PM
catmechanic07's Avatar
Images: 25
Liked 14 Times in 14 Posts
Default 1993 Ranger ?'s......
I have a friend that is needing some repairs to her 1993 Ranger ext cab. I will be replacing the water pump, thermostat, the belt, the wires and plugs. My question is....should I replace with all Motorcraft parts or aftermarket. Its just a daily driver with 128k miles. I dont know of anything that has ever been done to it besides regular oil changes and topping off fluids.
My thoughts: water pump...get a rebuilt
thermostat... motorcraft
belt...Gates
plugs and wires...Motorcraft (Ive had issues with aftermarket on Fords)
Lemme know......will be doing these repairs this coming weekend. Anything special I should check out while doing these repairs as well? I will also pressure test radiator while Im at it. I plan to steam the engine compartment area as well. Some say leave the engine running some say different while steaming it off......you opinions????
Black Sheep of FTC
Old January 26th, 2013, 07:57 PM
cheap lifetime pump from auto store
Stant T-stat
I worry about that thin skinned heater core under more than cap pressure
try to find a block drain
and dont use a chemical flush
Old January 26th, 2013, 08:52 PM
Images: 25
I was thinking Stant as well after I posted this.
I wanna go cheapest route but dont wanna do this time and time again from chitty parts
Black Sheep of FTC
Old January 26th, 2013, 09:44 PM
Yes on the MC plugs, wires, and reman Wpump. Stant and MC are fine for tstats. Had bad luck with Murray Tstats. Always test the Tstat befoe installing. As belts are concerned Gates is always a reliable choice as well as the Goodyear Gatorbacks. Though inferior to the other two, I've had good results with Dayco belts as well.
Old January 27th, 2013, 12:02 AM
Images: 25
Thanks for the info! Ill see what happens. I get parts at company cost plus 5%. She was gonna take it to a shop she usually uses but Im trying to get a car from her. Maybe she will give it to me after I do this and take down another cedar tree. Hmmmm!
Black Sheep of FTC
Old January 27th, 2013, 07:56 AM
it's nice that you help her out, but instead of trimming them trunks try nibbling them thighs for a better price
Old January 27th, 2013, 08:52 PM
Images: 25
Nah........Im good on nibbling! im married and she works with my wife! I dont think so! Ill stick to the summer lawn work, auto repairs and tree work!
Black Sheep of FTC
Old January 27th, 2013, 09:02 PM
Thumbs up you da Man
well your exactly correct and on the right track
as Southern Gentlemen it's our job to help the ladies out and those that are in need of a mans help; whether they be young or old, married or single
Old January 28th, 2013, 09:08 AM
I will not work on a married woman's vehicle outide of my own wife's. I will explain to the husband what needs to be done and help him spin a wrench but never just do it for her. Even if it's for so called good friends. Unless he asks me, i just won't be do it.
Old January 28th, 2013, 07:47 PM
Images: 25
She is a widow. He husband hung himself in their basement. She is 60 and lives alone. She does pretty well for herself but I hate seeing a good friend taking a vehicle for repairs because I know repair shops see a woman and see $$$$ signs. Id rather do the work for her and know its done right without ripping her off. She is good friends with my wife and my wife knows I go over there. Nothing sexual about anything AT ALL! Just being a polite gentlemen trying to help her out.
I got all the parts today. Will be doing all this this weekend after work. I looked at the radiator and its down about 6" in the filler neck so its leaking pretty good. The block behind the pump is green.....
Black Sheep of FTC
ASwaff400 , BigBlue79 , bikertrash3531 , Booba5185 , catmechanic07 , DoubleDee , Hotrodscoot , jostema , JSoko , Klitch , Lostin90s , Russo2 , skatebowd
PCV Reroute for 5.0\5.8 EFI (Pre-1993) Booba5185 Garage Talk: Shop Class 101 35 November 17th, 2012 05:41 PM
installing 1993 f350 instrument cluster in a 1960 f100 willd 1948-1983 Ford F100
7 September 20th, 2012 12:56 PM
1987-1993 and 1994 F-Series/Bronco, and E-Series Spark Plug Wiring BigBlue79 Garage Talk: Shop Class 101 1 September 16th, 2012 04:28 PM
1993 Ford Bronco Resurrected DIXIE FIX 1992-1996 Ford Bronco
21 May 1st, 2012 06:12 PM
Zappers 1993 Explorer Sport "Purple Haze" Pic heavy firezapper Ford Explorer 5 April 18th, 2010 12:11 PM
1993 , ranger
