Quantcast High idle - Ford Truck Club Forum
Ford Truck Club Forum > FORD BRONCO | BRONCO II > 1987-1991 Ford Bronco
Old December 1st, 2014, 06:57 PM
Moore1991bronco's Avatar
Moore1991bronco Moore1991bronco is offline
Images: 1
Default High idle
A pieced together motor in a 91' Ford Bronco, has A set of GT 40 heads off of a '96, 5.0 Ford Explorer, has a '96 5.8 EFI motor. It idles high at around 1500 RPMs, and when you give it gas, the RPMs go up but it takes a long time for them to fall back to 1500 after releasing the throttle. I recently put the GT 40 heads, new gaskets, and did an at-home port and polish on the heads. I can't figure out why it would be idling so high, because it didn't when I started this project. Any help is appreciated.
Old December 1st, 2014, 10:44 PM
skatebowd skatebowd is online now
Images: 247
Liked 36 Times in 34 Posts
have you checked for vacum leak
Old December 1st, 2014, 11:09 PM
Images: 1
I tried spraying brake cleaner around where I thought it might be sucking air
Old December 3rd, 2014, 09:13 PM
Images: 1
Well I got it running like it should be it was a broke ear on the plenum and changed the gasket so it must have been sucking air where the ear was broke thank you for all the help
Old December 4th, 2014, 01:27 PM
I spray with water
Old July 17th, 2018, 06:36 PM
TCBronc90's Avatar
TCBronc90 TCBronc90 is offline
Is this the correct spot to ask a similar question about high idle? Thanks, TCBronc90
Old July 17th, 2018, 11:30 PM
We do prefer if you start a new thread in the appropriate forum. Thanks!
(View-All Members who have read this thread : 11
Bigbluewindsor , crisman , glc , harrison28 , JSoko , KazMan , Moore1991bronco , Russo2 , skatebowd , TCBronc90 , vjsimone
Erratic Idle IrishKRO 1973-1991 Ford F150
11 September 9th, 2014 07:29 AM
High Idle to low idle dead spot Lostin90s 1992-1996 Ford F150
3 March 15th, 2013 09:45 PM
Egr , and idle solenoids. 2010Iron883 1973-1991 Ford F150
0 February 26th, 2012 12:01 PM
Looking for similar idle issue BigT67 1997-2003 Ford F150
11 June 14th, 2010 09:46 PM
idle rpm 95 5.0 chatterjj 1992-1996 Ford F150
3 January 3rd, 2010 08:38 AM
bronco , high , idle
