Quantcast 1995 F150 Wont Start - Ford Truck Club Forum
Old October 11th, 2009, 08:48 AM
Default 1995 F150 Wont Start
So I just finish loading up the truck (1995 f150) and hit my alarm button to unlock the doors and nothing. I hit it again... nothing. I bang the little box against the grill and press it again, still nothing. I repeat this for a good 20 minutes afraid to manually unlock my door and have my alarm screaming mid-day. I finally say screw it. I put the key in and unlock the door and I notice the side dome light was left on... The alarm did go off but it was so low that if I cleared my throat or coughed it would drown out the sound of the alarm. I knew then and there what was going on... the battery! This will be the third Optima battery in this truck in about a years time.
I waited 24 hours before installing the new battery. The truck sat over night batteryless and alarmless. I installed the new battery the next afternoon and the truck hadent run so good in months. The oddest thing.
Old October 11th, 2009, 01:09 PM
Where is our Audio Man?
Tony, can only think of three major reasons bad ground, a power drain or the alternator . Bad grounds are not as hard as power drains and the alternator can be tested after the hassle of remove/install.
I once installed a couple amps in my '90 camaro with the main power going directly to the battery instead of going through a switched circuit. Wont ever do that again. To top it off i ran the power wires next to the speaker wires under the door sill plate. When I put the screws back in the sill plate i unknowingly nicked the power wire and even replaced battery because I thought it was the culprit.
I believe even the "acc" wires (those are usually blue and yellow out of the radio harness) for phone and clock memory should go through the fuse block.
Old October 11th, 2009, 01:23 PM
My dome light was left on!
Old October 11th, 2009, 01:52 PM
so don't do that!
Old October 11th, 2009, 02:01 PM
Originally Posted by RedHot150 View Post
so don't do that!
Der!
Old October 11th, 2009, 09:26 PM
BigT67's Avatar
BigT67 BigT67 is offline
Images: 262
have you considered trying to put the timer on it that the newer trucks have?
Big T
Old October 11th, 2009, 11:15 PM
Hmmm... can that be done?
Old October 12th, 2009, 02:45 AM
BigT67's Avatar
Images: 262
probably more trouble than changing out a battery........
then again, someone semi-skilled in electronics could probably cobble something together that would have a timer associated with a set current load to trip a breaker.
Big T
Old October 12th, 2009, 07:59 AM
pull the bulb, throw it in the trash
be stealthy, live & work in the dark
Old October 12th, 2009, 08:16 AM
Best advice ever!
adoporto , Daryl56296 , yahnke
FordTruckClub.net Project F150 E303 Cam First Start FordTruckClubTV FordTruckClubTV 7 July 6th, 2012 05:22 AM
1995 F150 Engine Bay Cleaning. nine5flareside 1992-1996 Ford F150
7 February 7th, 2011 08:03 PM
1995 F150 Flareside Pointless Burnout FordTruckClubTV FordTruckClubTV 0 February 23rd, 2010 11:51 PM
1995 F150 302 5.0 Engine Build - Its My Turn! nine5flareside 1992-1996 Ford F150
9 January 17th, 2010 01:22 AM
1995 F150 4x4 Raised To Perfection nine5flareside Garage Talk: General Tech Talk 9 November 16th, 2009 11:41 AM
1995 , f150 , start
