October 23rd, 2009, 05:18 PM
Sweet looking tires!
October 23rd, 2009, 09:07 PM
Originally Posted by Webmaster
Rear end will be a Ford 8.8 with a trac lock unit already bought and I am thinking 4.56 as per suggested by GatorCrew who also has 37" tires. My issue now will be the front end and brake calipers.
he gave good info, but may not be low enough
do a check on the wheel & tire calculator
just my 2 cents, I like that quick giddy - up, as long a top end will reach your desired speed
to hell with HighWay Cruseing
double yess on BRAKES the additional weight/mass will reguire some exceptional STOPPING POWER
Rotors
Pads
Calipers (duel action)
but, of course I know you have already researched, and are close to a desision
question is, which BRAKE set-up
you are now able to go larger diameter, but will they be effective if you install a lift
which I hope you will not go to high, to accomadate the NEW Wheel set-up
think hard , and choose WISELY
sorry I do not have any recomendations for your TRUCK
PS dont let anyone tell you a 8.8 is weak
October 23rd, 2009, 10:01 PM
Good goin Webster :)
October 23rd, 2009, 10:42 PM
Thanks guys, as far as brakes I am really clueless. I kinda dont have the money to buy brakes right now so thats why I wanted to know the cheapest way to upgrade them. As far as the lift I am thinking 6 inch suspension and 3 inch body. So 9 inches total should do the trick. Again, if anyone can offer info on brakes PLEASE post it! Thanks in advance!
October 23rd, 2009, 10:45 PM
as scott suggested in your brake thread...it might be a good start to simply upgrade the brake pads to start to see if that would work out until you could afford the complete upgrade....
October 23rd, 2009, 10:46 PM
Just posted on other thread a few min ago.
October 24th, 2009, 03:56 AM
these loveable Trucks
like a Woman will get your money
October 26th, 2009, 09:12 AM
Come in Nine5
I discussed your Truck - tires and rear gear, with some knowledgeable folks
the outcome was split between
4.86 & 4.56
streetable & quick = 4.86
more highway = 4.56
decisions decisions
money money
October 26th, 2009, 09:29 AM
JSoko
here is the real question/questions...
Would the 4.56 be equal to the 3.31s I have now once I put the big tires on?
Would the 4.86 feel like 4.10s if I put 4.10s in my truck now with current tires?
Or even though I will have 37" tires both gears will still be better than if I had
4.10 gearing in my truck with my current setup as far as tires go?
October 26th, 2009, 10:12 AM
I called my friend
he would need more info on engine build
engine size - bore & stroke
cam type & duration @ .50, int. & ex.
fuel delivery, FI or carb
same questions he ask me before I chose a carb
cant undestand what the cam duration would have to do with a carb or rear gear choice
and when he explains it I still dont understand
anyway let me know, may can give you an unexplainable answer
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
