Quantcast 1999 ford f-150 sas - Page 2 - Ford Truck Club Forum
Old May 21st, 2010, 09:36 PM
Auto-hubs can always be upgraded to warn hubs.
your main issue with the newer axles should be whether or not you want to deal with the "Unit bearings" on the front D60's not liking larger tires with shallow backspacing (reversed wheel look)
The 97-03 f150's were heavy, the newer ones I believe are even heavier yet! the oil coolers really dont net much weight in the grand scheme of things.
You didnt confirm if you had all the fixins for fabrication either?
Old May 22nd, 2010, 01:36 AM
Originally Posted by Webmaster View Post
That would be DIXIE, me, old blue and aswaff are pre 1996 SAS.
and my SAS is a whole different animal of SAS! lol
Old May 22nd, 2010, 12:27 PM
catmechanic07's Avatar
Images: 25
Liked 14 Times in 14 Posts
Quote from Big Trouble: my f150 is the heaviest f150 I have ever owned she has the block heater from the factory.
Thats why I brought up the fact of the block heater Klitch. I wasnt "nit picking" about it. Just merely making a point. An oil cooler and a trans cooler doesnt mean anything either! Just part of a simple towing pkg added at the factory. All of my trucks have had them, even my Chebby! Heavier would mean thicker frame, beefier suspension, and heavier axles. Im not trying to bust his chops, just wanna make sure he knows what he's talkin about.
Black Sheep of FTC
Old May 23rd, 2010, 03:37 AM
BigTrouble's Avatar
BigTrouble BigTrouble is offline
mine has the 9.75 rear which most with the 5.4l triton dose but the same rear axle as the f250 super duty and yes I have access to the fab stuff like I said a full weekend and a couple cases of beer and I'd be set
Old May 23rd, 2010, 08:39 AM
Originally Posted by BigTrouble View Post
I'm wanting to do a sas in the future and was wanting to know if yall think a f-250 superduty front axle will fit.
To answer your question, yes it will fit. Basically any axle will fit as long as you have to correct tools for the job and the know-how to get it done. As you get more serious about doing the SAS, we will surely help you out.
Old May 23rd, 2010, 08:47 AM
Images: 25
OK! Now I see why you say its heavier. The F250 axle was only added under certain trucks. I dont know if it was an option, a mistake, or the factory trying something out. I recall seeing VERY FEW F250's with the same body style that you have. Most 250's and 350's ALWAYS had a different body style than the F150's. The model years like you have just somehow had a few F250's that Ford pushed out are a tester. Not sure how many know that..........
Black Sheep of FTC
  #17
Old May 23rd, 2010, 12:55 PM
Cat are you referring to the 97 F250 LD, which was similar to the F150 7700 pkg that I know nothing about?
BT: Find out which axles you want to start with, try to locate some and let us know. A few of us here have a certain vendor we've been buying from, so far he's treated me well, as well as Cecil.
  #18
Old May 23rd, 2010, 01:32 PM
Images: 25
Yeah! Those are the ones. I wasnt sure what models they were tho. I just recall seeing a few around these parts. Only real way to tell a difference was to see the badging on the fenders.
Black Sheep of FTC
  #19
Old May 23rd, 2010, 10:41 PM
DIXIE FIX's Avatar
Images: 504
Your truck has a 9.75 5 lug rear end... the superduty has a sterlin 10.25 and sterlin 10.5 the 10.25 has the 8x6.5 bolt pattern. The 10.5 has the 8x170mm.
  #20
Old May 24th, 2010, 12:49 PM
BigTrouble's Avatar
Thanks for the info on helping me out and I was going to try and fab every thing up wiht yall's help along with asking a friend of mine to build a custom leaf suppention on the front as it is still being drivin but i have to fix other thing on it first so I'll keep yall informed and I'll check that Info out on wich axel the 250 superduty's have and let yall know what I find out
4x4x4 , ASwaff400 , DIXIE FIX , jason77 , JSoko , Kickassguy , nine5flareside , sallyliao , Sc4x4truck , volvering , whitesleeper , willchase_19 , xxpaintballxx
1999 F150 302 swap DIXIE FIX 1997-2003 Ford F150
16 February 12th, 2011 10:29 PM
Ford and Toby Keith are giving away a 2011 Ford Super Duty Bates88 Garage Talk: General Tech Talk 0 June 30th, 2010 05:05 PM
1999 Ford Explorer Sport 2dr For SALE RedHot150 Vehicles For Sale
4 March 4th, 2010 03:39 PM
1999 F350 Super Duty 7.3 With Turbo Issue mustang512 1999-2007 Ford F250 | F350
17 February 18th, 2010 09:09 PM
1999 F150 Project: BEAST DIXIE FIX Garage Talk: Brakes & Suspension 66 November 26th, 2009 11:49 AM
1999 , f150 , ford , sas
