Quantcast Flywheel(Drive Plate?) Torque Specs??? - Ford Truck Club Forum
Old October 20th, 2012, 11:17 AM
adoporto's Avatar
adoporto adoporto is offline
Exclamation Flywheel(Drive Plate?) Torque Specs???
I can't find any torque specs for flywheel or what I think the book is calling drive plate. Can anybody elaborate on this. See Picture.
Haynes manual doesn't provide much info. unless I'm just missing it.
Name:	Torque specs for flywheel.jpg
Old October 20th, 2012, 12:34 PM
Chapter 2B (Page 2B-2) 75-85 Foot pounds.
Make sure you put thread sealant or black RTV on the threads or it will leak oil. Also, tighten them in a cross pattern, like you do wheel lug nuts.
Old October 20th, 2012, 02:22 PM
Page 3-16 in my Chilton's book also shows the samething. Just for any wanting to know!
Old October 20th, 2012, 03:44 PM
adoporto's Avatar
Cool see that now I was looking in the wrong place. Thanks Big Blue and booba. Went to the rubber vacuum system today and also replaced plenum and trottle body gaskets since everything is right there. Now gonna replace motor mounts and plugs, all should be ready after that. Am I forgetting anything?
Old October 20th, 2012, 04:20 PM
How'd that crossover pipe on the back work out? Rear main seal? oil pan? oil pump\screen? If it's on an engine stand, I'd do the valve seals too if you don't know if they are leaking or not. There's always plenty to do, lol.
Old October 21st, 2012, 05:46 PM
yes, valve seals are usually overlooked
Old October 23rd, 2012, 04:45 PM
adoporto's Avatar
The crossover pipe.....I just bent it back into place with a long screwdriver. I was afraid of kinking it but looks fine. Thanks
adoporto , BigBlue79 , Booba5185 , catmechanic07 , JSoko , rikard , Russo2
flywheel for a 1976 f-100 gooy1129 1973-1991 Ford F150
5 May 26th, 2012 06:54 PM
Find Your Truck Specs HawaiianF150 FTC Media Center
3 November 4th, 2011 12:14 PM
Ford Tech Specs 1964-1972 HawaiianF150 Garage Talk: Shop Class 101 0 October 29th, 2011 11:10 PM
Looking for FX4 specs Trav_450R 2004-2008 Ford F150
34 July 29th, 2011 02:51 PM
?Torque Wrench & Extensions ? JSoko Garage Talk: The Tool Depot™ 18 July 12th, 2009 10:01 PM
flywheeldrive , plate , specs , torque
