Quantcast 5.0L Roller Cam specs - Ford Truck Club Forum
Old December 8th, 2012, 08:50 PM
Default 5.0L Roller Cam specs
Anybody got the STOCK specs on Lift and Duration for the Hydraulic roller cams used in the 5.0L's? Trying to find a bit more aggressive grind profile over stock.
Also Lobe separation angle.
TIA!!
Old December 8th, 2012, 10:06 PM
only thing i can find in my manual...
Old December 8th, 2012, 10:21 PM
So it looks like .237" and .247", look right? That's what I got in my 1986 engine shop manual.
Old December 9th, 2012, 01:10 AM
Images: 624
Liked 185 Times in 167 Posts
that list dont tell you what your asking
Old December 9th, 2012, 01:14 AM
I believe there were 2 roller cams in these trucks, lemme see if I can find the info on them...
Old December 9th, 2012, 01:23 AM
This is what I can find so far:
The 1988 through 1991 blocks were all roller blocks, fitted with a flat tappet cam with these specs : 185 degrees duration intake/193 degrees duration exhaust@.050" and .379" valve lift intake/.395" exhaust. Starting with 1992 302 truck engines Ford switched to a roller cam, but with the same specs as the previous flat tappet cam,thus engine horsepower & torque ratings were the same. In 1994 engines, Ford gave the 302 truck engine a "warmer" roller cam with the following specs : 198 intake/200 exhaust @.050" and .422"intake/.448 exhaust,and re-rated factory horsepower from 185 net to 199 net(automatic),and 205(manual).
Old December 9th, 2012, 01:38 AM
Hmm, interesting, I think I've found the perfect cam for what I'm planning. More later.
Old December 9th, 2012, 01:42 AM
I tried uploading this to the gallery but it keeps saying invalid file...
Old December 9th, 2012, 01:51 AM
.278" and .266° I'll post the came I found in the mornin and compare.
Old December 10th, 2012, 07:59 PM
I'm looking between these 2 camshafts so far:
http://www.jegs.com/i/Comp-Cams/249/...rentProductId=
http://www.jegs.com/i/Comp-Cams/249/...d=#moreDetails
I'll more than likely order a Kit with all the lifters, cam, spider, dog bones, etc.
3rd-coast-thumper , ASwaff400 , BigBlue79 , bikertrash3531 , Booba5185 , bronco40 , donniedh , JSoko , Mike 87 F150 4x4 , nflfreak43 , rtdidaho , Russo2 , Thesmanman
Flywheel(Drive Plate?) Torque Specs??? adoporto 1992-1996 Ford F150
6 October 23rd, 2012 04:45 PM
HO roller conversion Booba5185 1973-1991 Ford F150
151 July 29th, 2012 01:01 PM
Find Your Truck Specs HawaiianF150 FTC Media Center
3 November 4th, 2011 12:14 PM
Ford Tech Specs 1964-1972 HawaiianF150 Garage Talk: Shop Class 101 0 October 29th, 2011 11:10 PM
Looking for FX4 specs Trav_450R 2004-2008 Ford F150
34 July 29th, 2011 02:51 PM
50l , cam , roller , specs
