Quantcast Official Engine Additives Thread - Page 2 - Ford Truck Club Forum
Old August 4th, 2012, 09:59 AM
Like i said i have used it for years.with out any negative results but cant positively say it helped I switched after reading these articals.
http://www.fuel-testers.com/is_gas_a..._e10_list.html
http://www.fuel-testers.com/review_g..._products.html
Old August 4th, 2012, 10:19 AM
Originally Posted by bikertrash3531 View Post
Product: Prolong Engine Treatment/ Booster
Manufacture: Golden West Lubricants
Claims: Reduces harmful friction and excessive heat in both gasoline and diesel-fueled engines Formulated with AFMT™ (Anti-Friction Metal Treatment) advanced technology Helps protect the engine in the event of oil or coolant loss. Helps restore engine efficiency to optimize fuel economy For both new and older, high-mileage vehicles. Free Lifetime Limited Product Engine Warranty.
Ingredients: Hydrotreated Heavy Paraffinic Distilates. No percentage given
Aromatic Petroleum Distillates. 300-500 ppm
Dewaxed Heavy Paraffinic Distillates (solvent) No percentage given
Proprietary Additives. (Non descript) No percentage given
Dose: one bottle of treatment initially with fresh oil (4-5 quarts). A bottle of booster at every oil change thereafter. No longer than 6mo or 6000 miles.
Two of my friends are dedicated race car builders one dirt track and the other short track.Both swear by and use pro long to soak and coat before builds.Example #1 Yogi's dirt track super modified car with 5 laps left got a hole in the oil pan lost all the oil finished the race and after disassembling and inspecting the engine there was no damage or wear.#2 Yogi was in his RV dragging trailer with pit buggie and grills n stuff on section of highway with no shoulders had some kind of complication causing oil lose drove several miles before being able to pull off road.Fixed leak issue got back on road finished trip with no negative results.
Old August 4th, 2012, 01:58 PM
Default Techron
Product: Techron
Manufacturer: Chevron Products Company
Claims: Cleans and protects vital engine parts to maximize performance and efficiency of todays modern engines.
Ingredients: Stoddard Solvent. 100 ppm
Naphtha (base solvent) 20% +
Trimethylbenzene. < 8%
Xylene. <3.55%
Cumene. <1.5%
Dose: 1oz per gallon every 3000 miles
Old August 4th, 2012, 02:18 PM
IMO Techron probably has the most science behind it.
Old August 4th, 2012, 02:28 PM
Default Star Tron
Product: Star Tron
Manufacturer: Star Brite Corporation
Claims: Unique enzyme formula improves performance in all engines. Improves combustion efficiency and fuel economy. Reduces emissions. Cleans entire fuel delivery system from tank to injectors and combustiin chambers. Removes carbon deposits and prevents future deposits. Ideal for ethanol blended fuels. Stabilizes fuel for up to two years. "Tune up in a bottle" Star Tron is fuel no need to worry of over dosing.
Ingredients: Naphtha 95%
Proprietary Organic Compound <.5%
Dose: 1oz per 6 gallons of fuel
Old August 4th, 2012, 02:32 PM
I have used Star Tron in my bike with noticeable results. I gained an extra 1mpg and got rid of all hesitation in throttle response. I have not used it in anything else. I prefer other stuff for my cages.
  #17
Old August 4th, 2012, 10:11 PM
catmechanic07's Avatar
Images: 25
Liked 14 Times in 14 Posts
I have heard nothing but good out of seafoam but Ive also heard that ANY additive is bad on a fuel system. I have found two gas stations here that sell ethanol free fuel. I have been running this for the last 4-5 tanks and seems to have a little better get-up to it. I also have a little tick to it and that has gone away also. I am trying to figure out this Diablo tuner and with it I can retard or advance the valve tick.
As far as engine/gears being seized, I use PB Blaster. Spray it down thru the spark plug holes and let it sit for an hour or two. The stuff will eat thru a foam cup so you know it has good penetrating properties.
Im a lil out there as where I work on large diesel engines but instead of using starting fluid, try using brake clean. It still contains an "ether" like ingredient but isnt as harsh on valves. I spray thru the air cleaner but i guess you could use the throttle body or carb.
Black Sheep of FTC
  #18
Old August 4th, 2012, 11:53 PM
Ethanol free gasoline will provide more get up and go than the E10 crap. If you weigh 200 pounds and take a 20 pound crap you'd get up and go a little better too. As far as additives being harder on the fuel system, i can't see how due to that most of the ingredients are already present in gasoline and with proper dosage the additive to fuel ratio really isn't that great. Especailly when broken down by ingredient. Admittedly there are some extra solvents thrown into the mix but IIRC i have used gasoline as a solvent many times. Just a guess but i would actually think that since they add more of the same (petroleum distillate), it might actually help some with the E10 dilemma we face. Not much but some. The additives i would try to steer clear of while using E10 are the ones with Isopropyl Alcohol (IPA) especially for storage. E10 is 10% alcohol, we get less efficiency with alcohol, why add more? Some may say its a drying agent, well, again, you already have 10% alcohol, why add more? If your running 100% gas than sure why not, give it a shot. Alcohol is hygroscopic in nature so it actually pulls moisture into itself. None of this is to say that any additive is not needed. Its an unfortunate truth that a majority of our fuels in this country are substandard IMO. So there is a call for these products. As you can see so far they vary in some ways and are common in others. Naphtha (white gas/ Coleman Fuel) being the most common.
  #19
Old April 7th, 2013, 04:13 PM
The Frankster's Avatar
Liked 12 Times in 9 Posts
Super job BT! After reading the story of prolong, I think I'll try it. I can say this about Sea Foam, my front tank would not register. One dose of SF and it has worked ever since. Hey guys, don't forget about your mowers and equipment. Non ethanol is best for older mowers, weedeaters and such. Food for fuel, what a waste. Hey BT, I can't think of it, but there is one that is suppose to have Teflon in it. Might be one you can add.
  #20
Old April 7th, 2013, 04:34 PM
I've heard Startron is supposed to break down the Ethanol in regular gas.
90f150xltcenturion , ASwaff400 , barriosman , BigBlue79 , bikertrash3531 , bluesky , Booba5185 , catmechanic07 , glc , Herbie , JSoko , nflfreak43 , nine5flareside , Russo2 , skatebowd , The Frankster , Tr00b
Official Junkyard Run Thread Booba5185 Garage Talk: General Tech Talk 68 May 4th, 2013 09:34 AM
The Official Stuck Thread DIXIE FIX Garage Talk: General Tech Talk 49 August 19th, 2010 11:03 AM
additives , discussion , engine , information , official , thread
