Quantcast towing problems - Ford Truck Club Forum
Old April 7th, 2015, 12:42 AM
lmatthysse's Avatar
lmatthysse lmatthysse is offline
Exclamation towing problems
First time poster, new to this format. I have an 05 350 crew, 6.0. less then 40K miles. Turbo was serviced in the past and upgraded turbo half installed. Runs fine until I purchased a 5th wheel and towed it home. on long uphill grads it would intermittently start making a fan rev'ing up sound and I would lose speed. Turbo boost look strong @ 20-25 at 3k rpm but once on one of the last times it happed bad, I saw the boost drop to 0 for a short bit before snapping back. Once over the crest of a rise and the throttle let up, the fan sound would usually fade and the drive would engage normally. As it got worse and persisted, I would pull over for a minute and shut down and restart and run strong till another hill load, but mostly the longer hill loads would make it go. I fear the worst.
Old April 7th, 2015, 06:48 AM
Liked 112 Times in 108 Posts
What are the rpm's doing when this happens (assuming automatic trans)? Again assuming automatic, are you using tow/haul mode?
Old April 7th, 2015, 09:11 AM
a friend had the same on his F450 6.0
got a new turbo and all has been fine
they told him that since he doesn't drive it much the vanes got stuck and would not open or close all the way
Old April 7th, 2015, 12:05 PM
lmatthysse's Avatar
It would happen in tow haul and not in tow haul. RPMs would hold at say 3000 rpm but the speed and power fell off.
Old April 7th, 2015, 12:06 PM
lmatthysse's Avatar
The weird aspect was the sound like a fan reving up when it would happen.
Old April 8th, 2015, 09:08 AM
I think that was from using engine only and higher RPM's
Old April 8th, 2015, 05:42 PM
less than 40K on an '05? geez! she needs to be driven!
do you have any way to monitor the vitals or pull any codes? like a scangauge or tuner?
how big of a trailer/ and what kind of grade was the hill?
ASwaff400 , Dirk , Ford-f250 , glc , harrison28 , jaybone94 , JSoko , Klitch , lmatthysse , martinleeo , river rat , skatebowd , XLTAlex , ZRU01
Towing with the 6.7 critterman 2011-2016 Ford F250 | F350
13 November 27th, 2018 06:54 PM
towing {(heavy towing) whats the max} michaelsnodgrass18 1992-1996 Ford F150
13 May 4th, 2013 01:32 AM
towing question truckin 2009-2014 Ford F150
6 August 30th, 2011 10:29 PM
problems , towing
