Quantcast 5.4 Block Drain Plugs - Ford Truck Club Forum
Old November 11th, 2014, 09:14 AM
Default 5.4 Block Drain Plugs
Does my '06 5.4 have engine block drains
I was told yes, but I just don't see them
anybody give me some clues
gonna drain the coolant, I got some MotorCraft Gold yesterday $14 a gal
not bad, 3 years ago it was $13
got it from the Dealer
Old November 12th, 2014, 02:35 PM
You won't need to drain the block if you use a Prestone flushing tee kit.
Old November 12th, 2014, 08:43 PM
yeah but any crap still goes to the bottom
I do have an old (from the '70's ) Prestone yellow plastic flush kit, it was Dads
but I have just installed a copper tee with extensions & threaded MIP with cap, on all our other vehicles
and you know crap settles to the bottom
I've had my '06 since 02/06 and it still has the original coolant
Where you reckon them plugs are at
on a 350 there's one on each side and easy to see and get at
I've look it up and found theres one next to the block heater - I don't have one
and on the other side its hidden
come on man share the wealth; give me a hint
Old November 13th, 2014, 11:14 AM
I don't have a clue where they would be.
If you haven't changed the coolant in 8 years it's a minor miracle that your cooling system isn't corroded and leaking already.
Old November 13th, 2014, 11:58 AM
I thought it would be about time
Truck has 51,000 mi. in 8 years
I know I should have changed it sooner (book says 100,000 mi.)
the reservoir looks clean, no staining
the radiator shows no signs of crud on the passage ways
in fact it looks like new
I'll let you know what come out when i drain it
Old November 14th, 2014, 11:28 AM
I thought the book said 5 years or 100k........
Regardless of the type coolant I use, I change it every 3 years.
I'd recommend you do more than just drain it - put a flushing tee on it and flush it.
Old November 15th, 2014, 07:07 AM
your right the book does say 5 years / 100,000
looked in there yesterday
3 years is smart
Old November 15th, 2014, 11:04 AM
here's what I have found on the drain plugs
one on each side
drivers side to the rear of the motor mount
passenger side next to or behind the starter
looks to be an counter sunk allen plug, some have used a T-50 torx
it's in super tight and may require heat as it looks as though it has red sealant (Red LocTite ?)
soon as i get around to doing the drain I'll post some photos
ASwaff400 , glc , JSoko , Klitch , MR_Pete , skatebowd
spark plugs f150man 1997-2003 Ford F150
8 July 7th, 2012 05:14 PM
How to Use a Self Tapping Drain Plug JSoko Garage Talk: Shop Class 101 0 March 21st, 2012 03:30 PM
Spark Plugs 5.8L BigBlue79 1980-1986 Ford Bronco
11 November 1st, 2011 06:21 PM
New spark plugs screwon23s 1997-2003 Ford F150
10 July 31st, 2011 08:48 PM
Which Spark Plugs? 2004FX4F150 2004-2008 Ford F150
4 December 11th, 2009 09:14 PM
block , drain , plugs
