Quantcast Another Question - Starting Troubleshooting - Ford Truck Club Forum
Old May 10th, 2019, 10:19 AM
sbpbrent's Avatar
sbpbrent sbpbrent is offline
Liked 3 Times in 3 Posts
Cool Another Question - Starting Troubleshooting
I seem to be posting the most questions, and unfortunately, I have another. So far, the answers from you all are batting 1.000 as I have managed to fix every problem on my 1978 F150 that has come up since I've owned it.
Same one, 1978 F150, 400M, Manual 4, 4X4, Ranger package, short bed.
Truck has been running well. This morning when I tried to start it and I heard a kind of an impact, a little grinding, and then sort of a whine. It's not turning over, but it isn't the battery, as it definitely has power.
I have all the wiring diagrams and a schematic of part of the starting system (under the hood only). So, where do I begin to search for the part that I need to order or wiring I need to check?
I should add, since I never have, I am Brent, a 58 y/o structural engineer from Colorado. I am married, no kids, cats, dogs, I'm a drummer, runner, and I have a 2009 F150 Super Crew XLT, too.
Thanks for all your help. Like I said, you are all batting 1.000.
Old May 10th, 2019, 02:15 PM
Sounds like the starter crapped out on you. You can jump across the solenoid to test it.
Old May 10th, 2019, 04:05 PM
Liked 105 Times in 102 Posts
Hopefully the grinding didn't take out any teeth on the flexplate.
harrison28 (May 10th, 2019)
Old May 12th, 2019, 10:06 AM
sbpbrent's Avatar
Thanks for the help. This one's weird. I changed the solenoid and as soon as I touched the negative terminal on the battery, the starter motor was spinning. It was like the solenoid I put on was stuck closed. The truck fired,but I shut it off quickly becasue the starter kept spinning after the start. I exchanged the solenoid at NAPA and the next one behaved just like the original one. It just whines.. I might pull the starter and bench test it but the headers make one of the bolts impossible to see, let alone remove. Another thing I need to check is battery voltage. I can't believe that if it pushes enough current to spin the starter that it can't trip a solenoid. The starter was purchased last December by the old owner, so it's not that old. I just have to keep checking, I guess. Thanks again!
Old May 12th, 2019, 11:06 AM
I would check the ignition switch.
Also note that there is a starter-mounted solenoid AND a fender or firewall mounted relay, which most people call a solenoid.
Old May 12th, 2019, 09:48 PM
sbpbrent's Avatar
It turns out, it was the 6 month old starter. Harrison got it. It was spinning, but it wasn't popping out to engage the gears. The NAPA near my house honored the warranty even though it was purchased by the previous owner at a NAPA 2-1/2 hours away.
Glc, yes I know the relay you were referring to. That wasn't the problem, but I am starting to get a good understanding of the starting system.
I am no mechanic. I'm probably not good for a backyard mechanic, but this '78 is easy to work on even for me. The weather is finally getting spring like here in CO, so I will take some pictures and post them here.
Thanks again! Brent
JSoko (May 13th, 2019)
glc , harrison28 , JSoko , RustyPile , sbpbrent
Starting from scratch lanejesse85 1992-1996 Ford F150
0 February 6th, 2015 10:22 PM
starting issues rollinblacksmoke 1948-1986 Ford F250 | F350
12 December 30th, 2013 11:47 PM
Starting A New Job JSoko General Discussion
6 April 5th, 2013 12:36 PM
Starting Problems Sekyridgerunner 1992-1996 Ford F150
7 October 17th, 2012 05:36 PM
Troubleshooting Antilock Braking JSoko Garage Talk: Shop Class 101 2 March 16th, 2011 09:30 AM
question , starting , troubleshooting
