Quantcast starting issue - Ford Truck Club Forum
Old July 9th, 2014, 01:22 PM
jones03100's Avatar
jones03100 jones03100 is offline
Images: 12
Default starting issue
i had the dash took apart for a few days just now put it back together and tried to start the truck it cranked a few time and i remembered i didn't plug the fuel tank switch back up so i plugged it up then tried to start it and nothing wont crank, but i jumped across the solenoid and it fired right up, so did the ignition switch just deiced to go out ???????
Old July 9th, 2014, 06:09 PM
Did you recheck the plug on the column? It could be a little off or you pulled a wire out when removing everything. You should be able to get a wiring diagram and start testing for power where it should be to kick the power to the relay from the key
adoporto , glc , HiRoller , jones03100 , Russo2 , Sclove ford
starting issues rollinblacksmoke 1948-1986 Ford F250 | F350
12 December 30th, 2013 11:47 PM
Starting A New Job JSoko General Discussion
6 April 5th, 2013 12:36 PM
RPM issue & starting issue rusty001 1992-1996 Ford F150
1 December 2nd, 2012 08:00 PM
Starting Problems Sekyridgerunner 1992-1996 Ford F150
7 October 17th, 2012 05:36 PM
issue , starting
