Quantcast Oil Pressure Drop 78 351w - Ford Truck Club Forum
Old September 18th, 2018, 09:37 AM
JedCrone's Avatar
JedCrone JedCrone is offline
Liked 3 Times in 3 Posts
Default Oil Pressure Drop 78 351w
I have a 1974 F100 with a 78 351 Windsor in it. My oil pressure has been on the low side of the gauge since I got the truck. I changed the oil and it stayed there so I just planned on putting something a little thicker than 10w-30 in next oil change. That was about 300-500 miles ago.
Just today, my oil pressure dropped to there very bottom of the "safe" area on the gauge. It would go up just slightly when the engine revved up but not that much. I've read that putting a new oil pump in or replacing the main bearings may fix the drop in oil pressure.
Any advice on what it could be? How to narrow down the causes? I considered just putting some Lucus additive in it to thicken up the oil. Thoughts on that? It's my daily so I need it in good shape.
Thanks,
Jedidiah
Old September 18th, 2018, 10:01 AM
Liked 99 Times in 96 Posts
Are you sure that it doesn't just need a new sending unit?
Old September 18th, 2018, 10:10 AM
JedCrone's Avatar
Not sure at all. How could i figure that out?
Old September 18th, 2018, 11:39 AM
JedCrone's Avatar
Well, had to go somewhere and driving back it went back to normal. It hovers right on top of the O of "oil" for the most part. So I guess thats good news. Still, is there a way I would know of the sender unit is going bad?
Old September 18th, 2018, 01:32 PM
A new sending unit is less then $20. It's only 1 wire attached on the top. I know nobody wants to just throw new parts at something hoping for a fix, but that's cheap enough to be worth the effort. It's located on the driver side in front of the oil filter.
Old September 18th, 2018, 03:42 PM
The only way you will know for SURE what your oil pressure is, is by removing the sender and connecting a mechanical gauge. You can have both if you install a T fitting.
Old September 18th, 2018, 06:16 PM
JedCrone's Avatar
Ok good to know. I'll look into it. Thanks for the help y'all.
Booger , glc , harrison28 , JedCrone , justridinaround , RustyPile
drop kits who makes a good kit? gaszoo2 1992-1996 Ford F150
13 August 9th, 2014 10:26 PM
5/7 Drop Round 1 = FAIL blackedoutv6 Garage Talk: Brakes & Suspension 9 July 8th, 2010 04:33 PM
2 Inch Rear Drop Shackles screwon23s Garage Talk: Brakes & Suspension 6 December 12th, 2009 02:31 PM
Groundforce 2" rear drop shackles Bates88 Garage Talk: Brakes & Suspension 12 December 2nd, 2009 04:18 AM
351w , drop , oil , pressure
