Quantcast Wet weather starting issues... - Ford Truck Club Forum
Old September 25th, 2018, 09:58 AM
frank5079's Avatar
frank5079 frank5079 is offline
Default Wet weather starting issues...
My truck seems to have a bad habit of not wanting to start after a heavy rain....this is the second time after a heavy, overnight rainstorm that it won't start the following morning.*
Old September 25th, 2018, 10:25 AM
Liked 112 Times in 108 Posts
How old are your spark plugs, distributor cap, rotor, and spark plug wires?
Old September 25th, 2018, 10:51 AM
frank5079's Avatar
I swapped the motor in last month and it's got all new distributor cap, rotor, plug wires, and plugs
Old September 25th, 2018, 12:45 PM
Check the coil for cracks and carbon tracks. Check the ignition module. Clean all the connectors in the ignition system.
Old September 25th, 2018, 12:52 PM
frank5079's Avatar
I've got an MSD blaster coil; I did tape up, lengthwise, the two lead wires leading up to the coil to where they go into the splitloom, about two inches...
Old September 25th, 2018, 02:49 PM
Does the starter work when you try to start it? Or is everything dead like a battery issue?
Old September 26th, 2018, 07:03 AM
frank5079's Avatar
New battery, new starter after the swap...starter cranks, engine turns over. Going to replace the new aftermarket cap and rotor with brand new Motorcraft replacements later on today, weather permitting...
Old September 26th, 2018, 10:51 AM
Before you do that - next time that happens, check for fuel pressure and check for spark. You need to positively determine whether it's ignition or fuel related.
Old December 28th, 2018, 06:56 PM
vjsimone's Avatar
vjsimone vjsimone is offline
What year ?
What motor ?
Cheers! Vinny
Old December 28th, 2018, 07:00 PM
vjsimone's Avatar
If your fuel pump runs longer than 2 seconds when you turn the ignition key on, your PCM may have issues.
Cheers! Vinny
69mock1 , bronco40 , frank5079 , FrankCoosy , glc , gt350 , harrison28 , JSoko , vjsimone
starting issues rollinblacksmoke 1948-1986 Ford F250 | F350
12 December 30th, 2013 11:47 PM
Trouble Starting Diesel Truck in Cold Weather JSoko Garage Talk: Shop Class 101 0 February 22nd, 2012 09:53 AM
For the weather minded people DoubleDee General Discussion
14 June 25th, 2011 02:27 PM
Good weather for some new pics (56K no) Agjake11 1997-2003 Ford F150
7 January 13th, 2010 12:42 AM
Hot Weather Roasts Western Washington BigT67 General Discussion
0 July 28th, 2009 08:33 PM
issues , starting , weather , wet
