Quantcast Oil In Radiator...help - Ford Truck Club Forum
Old September 12th, 2012, 03:37 PM
jelarf's Avatar
jelarf jelarf is offline
Default Oil In Radiator...help
well my little 350.00 project Ford Ranger seems to be plagued with a few problems...it has the 4 cyl engine and standard trans (non-auto) while going over the vehicle I found a lot of Oil scum in the radiator...smells like engine oil and is greasy like engine oil...now am an older guy (60's) and in my life that usually meant head gasket and/or warped head...but in these new fangled machines it could mean a lot more or a lot less...has anyone got any Ideas as to what it may be?...truck is not running due to fuel pump issue...for the price of 350.00 it's in pretty good condition...so a few hundred bucks getting it up and running would be ok...any more and I will just sell it...as is for a few bucks more...or maybe if possible dump another engine in...so I guess I am asking do you all think its a head gasket or what.
Old September 12th, 2012, 04:09 PM
DoubleDee's Avatar
Images: 669
I think 9 times out of 10 it is. How many miles on the 'ol 4 banger?
Is there any foaming/water on the oil dipstick?
Double(. Y .)Dee
SSG, TXARNG
How To Use The FTC Gallery
VIN Decoder
Big 3 Upgrade
Seat Removal
Interior Trim/Carpet Removal
Old September 12th, 2012, 04:18 PM
jelarf's Avatar
49,999.9 is what it shows but probably a 1 maybe a 2 in front of those numbers dipstick looks clean no water and no foam or ash look to oil
Old September 12th, 2012, 04:26 PM
Any power loss, smoke out of the tailpipe, or blowby?
Old September 12th, 2012, 04:30 PM
DoubleDee's Avatar
Images: 669
*cough*
*cough*
Jelarf, did you notice any of the symptoms Blue mentioned above before you undertook the fuel pump swap?
Double(. Y .)Dee
SSG, TXARNG
VIN Decoder
Big 3 Upgrade
Seat Removal
Old September 12th, 2012, 04:38 PM
jelarf's Avatar
no saw it run and went to haul it back and it started the fuel starvation so did not get a lot of time to check it out....kinda figured at 350.00 I could always sell it for the same to the junk yard...but its such a solid little truck with working AC..and here in AZ that's a real plus...I figure I can take the time and pull the head...and see what condition the my valves and head are in...I do wish I had a little more run time before it crapped out to run some tests but it is what it is...I was just hopeful...maybe it might be something else a little simpler...
Old September 12th, 2012, 08:43 PM
do yuo have water in the oil
Old September 12th, 2012, 08:44 PM
could be just a simple bad $18 gasket
Old September 12th, 2012, 08:47 PM
Have you done a compression check?
Old September 13th, 2012, 07:52 AM
jelarf's Avatar
I think with all my other "Projects" I am just going to sell it to the scarp yard, they will give me 500.00 for it and so off it goes on Monday to its final resting place...I am restoring two other cars and just don't see the upside to all the work...thank you for all your help and as always really sharp answers
BigBlue79 , bikertrash3531 , Booba5185 , catmechanic07 , DoubleDee , jelarf , JSoko , Klitch , nine5flareside , pete59edsel , Russo2 , sbellinghausen
Replaced radiator and sepentine belt BigRob 1992-1996 Ford Bronco
7 July 3rd, 2012 06:52 PM
1995 F150 Aluminum Radiator nine5flareside 1992-1996 Ford F150
5 July 4th, 2011 06:05 PM
1970 F-100 cab and radiator mounts wareagle247 1948-1983 Ford F100
0 June 24th, 2010 11:25 AM
Need a radiator for a '77 F-250 4x4....... 1977 F-250 4x4 Custom Auto Parts Wanted
2 April 23rd, 2010 11:43 PM
oil , radiatorhelp
