Quantcast Vac,pump oil leak - Ford Truck Club Forum
Old January 30th, 2013, 09:53 AM
Dave8N in Pa's Avatar
Dave8N in Pa Dave8N in Pa is offline
Default Vac,pump oil leak
I have a 1994 350,7.3 and its leaking oil from mount bolt in vacuum pump. I didn't think the engine oil went thru the vac.pump but it is dirty engine oil. The pump started making noise and the pully looks to be running out of line with the other pully's. Oil is dripping from the lower bolt hole. If engine oil doesn't run thru vac.pump, then it must be leaking from the head. The leak is fresh. I guess I will take the pump off and hope the head is not broken. If it is, maybe I can seal it with something. I can't understand how a head would break in such a way.
Old August 16th, 2014, 03:23 PM
leojr's Avatar
leojr leojr is offline
The vacuum pump has its own oil in it. Not much, but it does. It's on its last few miles. Get one and the pulley pulling/pressing tool now and replace it before it strands you.
96 F250 4x4 PSD auto CCSB
D60 axle swap with F350 front springs
SD (B code) rear springs and 4" factory F350 blocks
Explorer grab handles
Remote door locks work with engine running mod.
Link to my D60 refurb and OBS swap thread
Link to my OBS air vent R&R thread
90f150xltcenturion , ASwaff400 , bikertrash3531 , Bluegillfisher , Booba5185 , Dave8N in Pa , glc , Hemifish , joe250 , JSoko , leojr , Lostin90s , Russo2 , SlydinClyde
Firewall coolant leak? JCruz 1973-1991 Ford F150
12 September 3rd, 2013 07:44 AM
colant leak michaelsnodgrass18 1992-1996 Ford F150
22 January 21st, 2013 08:10 PM
1995 f250 351W vac line leak big boy toys f250 1992-1997 Ford F250 | F350
2 May 19th, 2012 04:51 PM
1994 Ford Ranger Fuel Lin Leak FIX Patch87 1993-1997 Ford Ranger
0 September 24th, 2011 09:01 PM
2006 expedition coolant leak & plugs JSoko Ford Expedition 5 October 13th, 2009 04:12 PM
leak , oil , pump , vac
