Quantcast Banks Speedbrake - Ford Truck Club Forum
Ford Truck Club Forum > GARAGE TALK > Garage Talk: General Tech Talk
Old May 4th, 2010, 01:04 PM
Bates88's Avatar
Bates88 Bates88 is offline
Images: 146
Default Banks Speedbrake
<p>Driving a 2008 to 2010 FordSuper Duty with a 6.4L Powerstroke? Looking to improve braking under load? Been searching for an exhaust brake? Can't find one?</p>
<p>This is where Banks Powercomes into the picture by revolutionizing the exhaust brake industry with their all new electronically controlled patented Speedbrake. By manipulating the turbo, gear selection and torque converter clutch application you can cruise down any hill at your desired speed. Completely automatic and hands free the Speedbrake will work with any Bankspower tuner and Banks iQ-interface combo.</p>
<p>There are three different ways the BanksSpeedbrake can work for you. The first way is like a standard exhaust brake so when you let off of the throttle it will start to slow the truck down. The second is you can coast down a hill and when the brake needs to be activated simply "tap" the brake pedal. The third way is to set the speed setting and your truck will maintain that desired speed all the way down, kind of like a reverse cruise control.</p>
<p>Another nice benefit of BanksSpeedbrake is you can adjust the brake settings to high, medium or low strengths. The easy touch screen control displays, among other things, current vehicle speed, braking effort, transmission and engine coolant temperatures. This system can alsowarn you onscreen to excessive coolant or transmission temperatures.</p>
<p>This system has the OBDII scan tool capability that reads, interprets and clears codes. The Speedbrake does not require any exhaust modifications and has an easy install with some simple under hood connections.</p>
<p>Banksspends a lot of time on their research and development of new products and it shows with their new Speedbrake. Leave it to Banks to cover all of your trucks performance needs.</p>
<p>To discuss this blog entry click [HERE]&lt;/p&gt;</p>
(View-All Members who have read this thread : 0
There are no names to display.
Banks Ram-Air Intake Purchased... TedC 2004-2008 Ford F150
15 August 5th, 2010 06:52 PM
Banks Ottomind Programmer Bates88 Garage Talk: General Tech Talk 0 January 18th, 2010 09:03 PM
Banks Monster Exhaust Bates88 Garage Talk: General Tech Talk 0 November 5th, 2009 02:29 PM
Banks link Bates88 General Discussion
0 August 7th, 2009 12:55 AM
Banks Programmer Bates88 Garage Talk: Engine & Drivetrain 14 July 18th, 2009 02:35 AM
banks , speedbrake
