Quantcast 302 Engine - 331 Windsor Stroker for Sale - Ford Truck Club Forum
Ford Truck Club Forum > THE MARKETPLACE > Auto Parts For Sale
Old November 16th, 2012, 05:19 PM
Thumbs up 302 Engine - 331 Windsor Stroker for Sale
this engine was to be used in my AC Cobra, used a 427 instead
this 331 has not been fired up
all the following for $4,500, send me a PM if intrested ~ Cash Only, Atlanta area ~
Ford Windsor 331 cu.in. stroker
438 HP @ 6800 RPM's
This Engine was built for use with a Nitrous & Super Charger in mind
A 'Pro Charger' http://www.procharger.com/
Ford Block:
bored .030 over
Decked to .005
Compression 10:1
Crankshaft:
Eagle Forged 4340 internal balance
Micro Polished
Clevite 77H Rod & Main Bearings
Rod Bearing Clearance .002
Main Bearing Clearance .0025
1/2" Main Bolts
Connecting Rods:
Eagle Forged H Beam 5.400
Cylinder Heads:
World Products Windsor SR. 64cc
Surfaced .010
Bowl Ported
Blended Valve Job
Trick Flow Intake Valves 2.020
4 Angle Intake Seats
Trick Flow Exhaust Valves 1.600
Full Radius Exhaust Seats
Pistons:
JE Performance Coated .030 Flat Top
JE File Fit Rings
Comp Cams Custom Grind Cam Windsor Firing Order
Comp Cams Lifters
Comp Cams Pushrods with Guide Plates
Comp Cams Valve Springs
Scoripion Roller Rockers 1.6F - 3/8" studs
Clevite Cam Bearings
Melling High Volume Oil Pump
Melling Oil Pump Shaft
Melling Double Roller Timing Chain
Pro Products Damper/Balancer 80006
Ignition:
MSD Pro Billit Dist 8352
MSD 6AL Ignition Box
MSD 868 Ignition Adjustable Timing Control - for Nitrous usage
Edelbrock High Rise 'Air Gap' Intake Manifold (Chrome)
Carburation - Shiny 600 Edelbrock, includes jets, metering rods, step-up springs, retaining springs and needle kit
I'm keeping the 650 Holley Double Pumper
High Volume Water Pump & T-Stat
ARP Chrome 12 Point Bolt & Stud Kit
Fel-Pro Gaskets
Will sell the carb for $200 ~ Cash Only, Atlanta area ~
Edelbrock EDL-1406 600CFM - electric choke, all linkage to include Ford kick down linkage for auto trans
and a EDL-1487 Calibration kit for the 1406 (jets, metering rods, step-up springs, retaining springs)
currently set up for performance
all in new condition for $200
Old November 16th, 2012, 06:46 PM
thats an awesome motor joey!
Old November 16th, 2012, 07:12 PM
hope CAT don't hear you call it a "motor" he & I went round & round backin '06 about calling a motor a motor LOL
you can look in the plug holes and see the shiny piston tops
it would be good in a boat also and look good too
Old November 16th, 2012, 07:23 PM
Will sell the carb for $200 - ~ Cash Only, Atlanta area ~
Old November 24th, 2012, 12:20 PM
above prices are negotiable
Old November 24th, 2012, 11:49 PM
Is it flat tappet or roller? If it's flat tappet, I assume it hasn't been broken in yet?
Old November 25th, 2012, 01:28 AM
Comp Cams flat tappet solid lifter
Old November 25th, 2012, 10:31 AM
post deleted
Old December 1st, 2012, 08:12 PM
probably will just save this one
AllenDKull , ASwaff400 , Big Black 007 , BigBlue79 , bikertrash3531 , BlackFlameCustoms , Booba5185 , cblachly7808 , jared96 , JSoko , latemade5.8 , patrickg450 , RACERSTEVE , rtdidaho , Russo2 , Sc4x4truck , The Frankster , Zach Willard
300 inline 6 swap to 351 windsor H.O Zach Willard 1973-1991 Ford F150
14 November 4th, 2012 10:58 PM
331 Stroker build advice please FlaresideFan94 Garage Talk: Engine & Drivetrain 9 July 13th, 2012 12:55 PM
How to Stroke Any Engine - Stroker Science JSoko Garage Talk: Shop Class 101 0 May 18th, 2012 10:50 AM
= stroker = whitesleeper Garage Talk: Engine & Drivetrain 6 January 28th, 2012 11:51 PM
302 5.0 Engine For Sale Trav_450R Auto Parts For Sale
2 April 11th, 2010 07:58 PM
302 , 331 , engine , sale , stroker , windsor
