Quantcast Running a MSD ignition bypass a ICM? - Ford Truck Club Forum
Old September 9th, 2014, 02:26 PM
adoporto's Avatar
adoporto adoporto is offline
Default Running a MSD ignition bypass a ICM?
I posted a topic a while back and the problem pointed to the ICM, well just now getting around to replacing it and was wondering since I am running a MSD ignition does that bypass my ICM?
Could it be that my MSD is bad?
1992 F150 XLT 4x4- 1995 donor motor 5.0/302
Mods: K & N intake, MSD ignition, Reroute PCV, Rubber Vacuum System, and Remote Start
Soon to come: Long tube Headman Headers
Old September 9th, 2014, 02:29 PM
adoporto's Avatar
Sorry meant to post in 92-96 Forum! Can someone please move?
Thanks
Old September 11th, 2014, 12:04 PM
adoporto's Avatar
I went ahead and just replaced ICM after unplugging it and tried to start truck with no success. So I guess that answers my own question that the ICM still does something.
Since I replaced it, and no problems with the truck cutting out while driving or turning.
It was tough getting the screws out that were holding it to the heat sinks. If anyone ever has this problem its a 7/32 deep socket and doesn't fit well in the little holes but it worked.
Thanks
Old September 15th, 2014, 10:35 PM
adoporto's Avatar
Okay, thought the truck was fixed and yesterday it did it again! I was driving and it just cuts out or dies. Once on side of the road if I let it sit for a few minutes boom thing starts up without a miss. Don't understand. Could I have gotten a bad ICM?
Thanks
Old September 16th, 2014, 07:25 AM
when i had an issue with my ICM, i ended up having to replace the distributor also as it fried the module in the dizzy. replaced both at the same time, no issues after that.
Old September 16th, 2014, 03:40 PM
adoporto's Avatar
Good to know thanks Aswaff400!
Old September 16th, 2014, 04:54 PM
adoporto's Avatar
So as I was reading Aswaff400 post about distributor I thought I would check the wires out and I disconnected the coil wire everything looked ok. As I was pushing down on the wires one of them made a snapping sound like it wasn't pushed down all the way. It wasn't the coil wire just one of the 1-8 wires. Could this be the problem I thought it would miss real bad not just completely shut down vehicle. Correct me if I'm wrong.
When I get home I'm going to check out the distributor cap, rotor, and meddle around some more. Who know what I will find.
Old September 16th, 2014, 08:27 PM
Images: 622
Liked 182 Times in 164 Posts
see if any of these help
https://www.google.com/search?q=ICM&...F-8#q=ford+ICM
Old September 17th, 2014, 01:40 AM
adoporto's Avatar
Thanks Jsoko for the read. I am going to test my ICM. So I also replaced my distributor and left the truck running for about 15min and no problems. I will see what happens tomorrow.
Old September 17th, 2014, 12:44 PM
adoporto's Avatar
Angry Flat Tire
When it rains it pours not only is the truck turning off while driving and has a hole in a hose/pipe that I can't seem to identify. Go outside and my worn down BFG All Terrains have a leak. Flat to the rim, they are done for, at least that one, so now looking at buying 4 new ones. Good for me BFG are currently offering a discount . Had to start the back up. Just glad it stopped raining!
adoporto , Adsquared , ASwaff400 , Colorado Ryno , glc , Herbie , JSoko , judd94 , MR_Pete , pete59edsel , Russo2 , The Frankster
Federated Tech Talk - Ignition Coils Two Guys Garage Two Guys Garage 0 August 19th, 2013 03:11 PM
how do i remove ignition lock ? joe250 1973-1991 Ford F150
11 April 22nd, 2013 08:32 AM
1969 Camaro - ACDelco - Ignition and Oil Change - LS Two Guys Garage Two Guys Garage 0 April 3rd, 2013 10:51 AM
ignition problems. Motormike 1948-1983 Ford F100
5 November 14th, 2012 09:37 AM
How to Install a Heater Core Bypass Valve Booba5185 Garage Talk: Shop Class 101 1 February 4th, 2012 08:37 PM
bypass , icm , ignition , msd , running
