Quantcast Dana 44 - Operation Break Down - Completed - Ford Truck Club Forum
Old December 30th, 2009, 09:06 PM
Arrow Dana 44 - Operation Break Down - Completed
Well I have a 1995 F150 with the crappy IFS front end. I've decided to do the SAS. I bought a high pinion Dana 44 front axle out of a 79 Bronco. I have yet to actually look up the serial number to make sure. It's not really important. Below will be the entire disassembly of the axle, removing old paint and then repainting it. The rebuild will be another thread!
Just a little side note about this particular axle:
1978 and 1979 were identical.
What makes this axle different to 1977 and older is one important thing, the
78-79 axle have the radius arm wedges molded into the housing as one piece.
The previous years, 77 and older, the radius arm wedges were welded on after
the housing was casted. So what does this mean to you if you're buying a d44?
This axle is setup ONLY for radius arms. Leaf springs or a 4 link setup can't be
done with the 78-79 axle. Do your homework! Ask around if you are not sure.
12/16/09
Here is the axle when I picked it up... six hours of driving... trip sucked! Axle is heavy!
5 x 5.5 Lug Pattern and Manual Locking Hubs:
A Bit Rusty But Nothing Major (from the outside):
Here is Some Misc Parts From The Axle:
12/29/09
The Dana 44 Break Down Begins
First Project is to open The Differential Cover:
The Tools I used Were My Craftsman 1/2 Ratchet w/ Extension, Socket and Gloves.
To remove the diff cover I needed the 1/2 inch socket.
To remove the bearing cap bolts you will need a 3/4 inch:
After Making Sure There Was No Oil Inside I started To Crack It Open (1/2 inch socket and 6 inch extension):
A bit rusty, the oil was drained before I got it:
Be Sure To Keep Everything In Order... trust me:
All looks well so we are moving on. Now its time to remove the axle from the housing. First thing is to remove the hub:
I had to remove 5 little bolts with an allen key, pretty simple so far:
Remember, KEEP EVERYTHING TOGETHER:
Next, give the hub cover some soft taps with a rubber mallet until it pops off:
Here it is:
Before we go on, lets remove the brake caliper before it gets in the way, first unscrew this:
Now with a hammer and flat head just some taps will get this right out of the groove:
Next some nice and easy shots on both sides with a hammer should pop the caliper right off:
Piece of cake, lets rock n' roll:
OK next is time to remove all the hubs guts so we can slide the rotor assembly off:
There is a ring here sitting in a channel holding all this is.
Just pry it out gently with a thin nail or screwdriver.
If you look at the image two pics down its the ring on the right:
Once you get that unscrewed pull it away very easy because there are some guts that may fall out:
See... guts! (Theres the ring on the right):
OK. Moving on, this next step was a little tricky. There is a clip that has to be removed.
This clip needs to be spread apart to be removed... I dont have the correct tool for it:
Sorry about the blurry pic but you'll see the clip soon enough. Anyway, I found a pair of
needle nose pliers and decided to grind grooves into the tips so the clip would sink into:
Now that my tool is ready, it's time to party! OK lets get back to work, on the clip:
OK so we got that off... lets see what it was:
In this next image, this gear was giving me a hard time so I drowned it in WD40 to get any
grit that may be stopping it from sliding right off. It's supposed to slide right off:
Once that gear is out, this just falls right out:
Next, gently pull this out with a thin flat head:
Believe it or not, it's time to remove the rotor!
All gone:
We will take these bearings out and call it a day:
12/30/09
Picking up where we left off
Next project is to finish taking this damn thing apart, we will start with the spindle, gently hammer bolts out:
All but one are able to come out and that's fine, the knuckle will be in the way:
My plan is to keep the spindle, but it needs to be banged off...
so to save the threads I used a 2x4 and hammer:
That plan sucked:
Well after splitting another 2x4 I said to hell with it and I banged it off:
Yummy!
Slide the axle out nice and easy:
That's it for today but next time we will work on removing the knuckle:
1/28/10
Just about done
Time to remove the knuckle, the castle nut just kept spinning because of the ball joint it
was bolted on to, so I decided to finally use my dremel! I was getting new nuts anyway:
OK outsides cut off, now its time for the inside nut (surprisingly, this one came right off)
Just bang out the ball joints and the knuckle will fall right to the floor (watch your toes):
OK time to remove the carrier!!!! This was a pain but two pry bars worked wonders:
Be sure to losen the bearing cap bolts but do not remove them. When we pry the carrier out
we dont want it to fall, so by keeping the bearing caps on but loose, they will catch the carrier:
Lets move on. Position the bars inside the housing in a way that DOES NOT damage the carrier:
After some struggling and more struggling and a little more, the carrier will pop right out.
Once loose, remove the bearing cap bolts and then remove the bearing caps, nice and easy:
Pull the carrier and ring gear out and place it in a safe place:
Now it's time to remove the pinion gear:
This nut was the biggest pain out of the entire project:
I wasted no time, well about 2 days, time for the dremel again make sure to WEAR eye protection:
OK that was fun...pinion gear dropped right to the floor! I guess I wont be re-using this:
Well after all that rust earlier all over the ring gear and bearing caps I was a little worried,
but this thing is squeaky clean:
2/4/10
Time to remove all its sin
Well, I started cleaning this in between days where I was stuck. Heres the progress:
Just about all paint removed:
Now it's time to paint this thing, first thing was to take care of any rust that I missed
and to seal it from future rust, then prime and paint with hi-temp paint:
Just about done:
TODAY 2.09.10 ITS ALL DONE FINALLY!
And a close up:
Side note... I didn't remove the drivers side knuckle, rotor, hub or anything. The drivers side was completely
broken down already by previous owner. This project is over. Next project will be the rebuild of this axle.
To be continued.
Old December 30th, 2009, 10:20 PM
Agjake11's Avatar
Agjake11 Agjake11 is offline
Images: 2
looks like a sweet build project. what wheel and tire setup are you gonna run?? more lift?
04 F250 Lariat FX4 6.0L PSD - EGR Delete/Straight Piped - SCT w/ Gearhead Tunes - Edge CTS w/ EGT
04 Chebbie Tahoe LT - Stock w/ Nav and Bose - Pink TTS Sticker
Old December 30th, 2009, 10:55 PM
Old Blue's Avatar
Old Blue Old Blue is offline
Images: 384
what gear ratio is the solid axle??? are you gonna keep your original gears are do a upgrade front and rear?
Monthly Recognition Moderator
Check out my videos HERE
Old December 31st, 2009, 12:40 AM
Here is what I have already for the truck:
37" TOYO open country M/T
Im thinking of a 10 inch lift because I have a set of 16" M/T classic rims with the beadlock ring that are size 16" and I want to put the same tire on but in 38" (for the open country 16" rim 35" or 38" are my options).
Old December 31st, 2009, 12:44 AM
Agjake11's Avatar
Images: 2
gonna be a big jump from how it looks now but should look awesome. i love those tires
Old December 31st, 2009, 12:49 AM
The axle has a 3.55 gear set in it now I believe. I am not keeping it, I am going to upgrade to 4.56 gears. Not sure what brand yet.
Old December 31st, 2009, 01:03 AM
Old Blue's Avatar
Images: 384
Congratulations on the beginning of loosing your sas virginity
Old December 31st, 2009, 08:33 AM
cant wait to see the end result! should look bad ass!
Old December 31st, 2009, 08:46 AM
Damn Nine5, I hope that aint the bed of your '95
I know you cant wait to get it all together, work smart
LOL you seem to be a fan of long extensions
Old December 31st, 2009, 10:55 AM
It is! One of the last things I plan on doing is removing the bed. Welding a plate of steel behind it to strengthen the back wall after I bang out some of the dents. Then rhinoline it or maybe do the duplicolor bed liner myself.
work smart
« There is no previous thread | Need Help With Dana 44 Build »
BigBlue79 , bulldogginford , CharlieM , CoCrawler , faulkenberrycameron , HiRoller , nydon , pegmeister , Russo2 , Sc4x4truck , whitesleeper
SAS F150 2.5 Ton Monster DIXIE FIX Garage Talk: Solid Axle Swaps 67 October 3rd, 2010 02:31 AM
Need Help With Dana 44 Build nine5flareside Garage Talk: Solid Axle Swaps 2 April 27th, 2010 11:42 PM
ND recruit dies in spring break accident BigT67 General Discussion
0 April 3rd, 2010 10:19 AM
Vented Loudspeaker Enclosure Contruction and Operation SoundScape Garage Talk: Shop Class 101 0 November 27th, 2009 11:33 PM
break , completed , dana , dana 44 , operation , rebuild
