Quantcast 1995 f-150 Dana 44 SAS - Solid Axle Swap - Page 5 - Ford Truck Club Forum
Old February 11th, 2011, 12:29 PM
Cecil, will a 9 inch tall spring start to bow?
  #42
Old February 12th, 2011, 03:33 AM
DIXIE FIX's Avatar
Images: 504
from everyone that i have talked to, the 9" springs from jeffs bronco graveyard will settle maximum 1-1.5". If the truck is too short after they settle you can move the shock tower lower for more lift.
  #43
Old February 12th, 2011, 11:14 AM
fbm1344t's Avatar
fbm1344t fbm1344t is offline
Images: 17
For the shock question i know what your trying to say ill have to go measure in a little. The coil buckets are a sort of rare item but you can use the stock ones its just that like the 66-77 ones they will give slightly more lift, but will limit you to a stud type shock which is undesirable. i used a f-350 drag-link not track-bar, this is because the 78/79 steering box is outside the frame rails which makes the stock nonadjustable 78/79 drag-link a bad choice since it would have to be shortened. the drag-link for 92,93,94,95 f350 works perfect, is adjustable, and even has a slight bend to help with clearing the diff. hope this helps and ill be sure to post that measurement for you in a little while.
-Dan
1995 F-150 4x4
4.9l m5od 3G swap
8" lift D44 SAS
35" Mud Rovers
  #44
Old February 12th, 2011, 10:26 PM
DIXIE FIX's Avatar
Images: 504
-Dan
thanks alot buddy. I found a set of coild buckets from a 78 for $50 so im good there. Im gonna be running hi steer arms with hiems since i have all the DOM and hiems from my F150 build and since ill be staying lower it should fit fine. I should actually come out less $$$ because of the parts that I already have.
  #45
Old June 29th, 2011, 10:25 PM
willchase_19's Avatar
willchase_19 willchase_19 is offline
You have got the best looking Ford 150 truck parts there. I was hoping I could do the same for my pick up. Been looking for videos to where I can find instructions for this. I already got my parts, bought it from a good source. high quality stuff. What;s left is to put all stuffs together
  #46
Old August 7th, 2012, 09:27 PM
BIGCOUNTRY's Avatar
BIGCOUNTRY BIGCOUNTRY is offline
Images: 4
Quick question fbm1344t I just recently did a sas on my 93 f150 with the same front end will the78 f150 Pittman arm bolt to a 93 steering box?
  #47
Old September 16th, 2014, 08:10 PM
bronco hero 94's Avatar
bronco hero 94 bronco hero 94 is offline
Images: 5
2.5" tuff country f-350 track bar bracket
what year is it or part number
« 95 EXT cab SAS | There is no next thread »
(View-All Members who have read this thread : 81
1992f150raptor , 1stockpstroke , 4x4x4 , 95_150 , 975.4 , abosely , adoporto , alohabrewer , ASwaff400 , azfordman , Bates88 , Big Black 007 , BigBlue79 , BIGCOUNTRY , BigTrouble , Booba5185 , brads93bronco , bronco hero 94 , btripodina , buckshot , bulldogginford , chief0331 , chris_95f150 , chris_c95f150 , crd1982 , DBRN409 , dferrel , DIXIE FIX , drvshft , duke daddy , Erik150 , f1504x4driver , F350mark , faulkenberrycameron , fbm1344t , firezapper , ford small block , FORD TRUCK FAN , Fordtruck1992 , ford_4_life , gary939495 , greghinkel , HARLEY589 , HellOnWheels , infoleather , IrishKRO , jasoncarpenter1 , JSoko , keo4579 , kidd1994 , Klitch , Kmh3212 , Mbeezy618 , michaelsnodgrass18 , mtdracing , Mtgoat , MTN.BRONC , mucklife13 , M_Erber , nine5flareside , NomaFord , Ol Red , Pluto , polargeek , Red91 , Russo2 , sbellinghausen , Sc4x4truck , Scott12345 , Skidoo03440 , Stewy 39 , team1360 , tity04 , tylerbotts , volvering , whitesleeper , Whitey , willchase_19 , Woconn1 , zippois1 , zmr2010
1995 , axle , d44 , dana , f150 , sas , solid , swap
