Quantcast ;) I found my own - Ford Truck Club Forum
Ford Truck Club Forum > FORD BRONCO | BRONCO II > 1966-1977 Ford Bronco
Old July 21st, 2011, 03:38 PM
Default ;) I found my own
She needs love, but not a lot. floor pans, some surface rust tamed, and drivetrain for the most part. Roof support for the top is caving in the center, kind of odd...
alas, here it is, next to my dads 67 which is all original.
My new to me, 66. $1400.
Old July 21st, 2011, 10:21 PM
whitesleeper's Avatar
Default Sweet
That looks like a hell of a deal
Old July 22nd, 2011, 08:54 AM
so when will we see stitches' drivetrain in that thing? lol
Old July 22nd, 2011, 12:56 PM
Images: 622
Liked 182 Times in 164 Posts
I know you felt good when you found it; will this be a Father & Son project ?
PS next time spend $ on some Trees LOL
Old July 22nd, 2011, 04:07 PM
I dont need to do backflips :P Stitches motor/trans may eventually wind up in the 67 fairlane though, if i ever start on it.
Not quite a father-son project, but he will be around to give me pointers, and tell me what I'm still missing.
What are trees? I planted two and one died :/ lol :thumbsdown:
:twothumbsup: I've seen running ones with rust everywhere for $3500. I feel decent with a rolling chassis and mostly complete tub/body for $1400. I need to find a D44 for it though, the D30 i hear is too weak.
Old July 22nd, 2011, 07:05 PM
Nice! Cut the roof off, lift it 9 inches and put some 38's on it!
Old July 23rd, 2011, 01:42 PM
I'll just unbolt it
Old December 27th, 2011, 05:12 PM
Looking for some knowledge shed on my bronco
I found an ad that has a t-case from a later year early bronco, the J handle dana 20.
But the same guy has some truck stuff for sale I'm unfamiliar with, what is the NP435? Is it the truck trans with granny low? 3spd?
NP 435 with married 205 transfer case $250
NP 435 with Advance adapter to Dana 20 transfer case $400
Would either fit in the bronco?
Old December 27th, 2011, 06:13 PM
New Process 435 is a truck transmission that is 4 speed with Granny 1st, there is two different 1st gear ratio's the one you'll want is 6.69:1 1st gear. IDK if it'll work in the 66-77, but they did use it in the Big Bronco's.
Old December 27th, 2011, 06:16 PM
The New Process 205 t-case is damn near bullet proof, it is a gear driven t-case and takes alot to blow it up. Cast iron case, it is stronger than the Dana 20, in the IH Scouts they swap out these Dana 20's for either the Dana 300 or to swap in a 205.
I sold my 2wd Np435 for $150 as it would cost near $500 for the tailshaft adapter for 4x4 transmissions, $250 is a good price if the transmission shifts fine, and the t-case shifts fine, if you take a look at it shift the tranny and see how smooth it is, I usually like to pop the top off of em and look at the gears but then you gotta replace the gasket there.
I have seen these swapped in to the 66-77 Bronco's, there is a site dedicated solely to the 66-77 classicbroncos.com that may be able to shed some light on it if your interested.
« General 1966-1977 Bronco information | There is no next thread »
(View-All Members who have read this thread : 41
975.4 , ASwaff400 , BigBlue79 , BigRob , BigTrouble , bikertrash3531 , Booba5185 , CrazyD , DIXIE FIX , DoubleDee , F150GT , Firedog67 , harrison28 , HawaiianF150 , herbz , jallen3521 , JSoko , Klitch , labford , Lostin90s , marmaduke , michaelsnodgrass18 , nine5flareside , NomaFord , ONELOWF , pete59edsel , Raleigh , Red91 , Ridgerunner , rtdidaho , Russo2 , sbellinghausen , Schumi112 , screwon23s , skatebowd , Soxfan68 , Stewy 39 , Tr00b , Wheelsblank27 , whitesleeper , Yankee
I found it fsawer New Member Introductions 3 January 25th, 2011 09:10 PM
Look what I found! Part 2. SS FatMan Ford SVT Raptor 15 January 6th, 2010 06:10 PM
Look what I found! SS FatMan Ford SVT Raptor 7 December 25th, 2009 10:04 PM
Look what I found at my dealer! RedHot150 Ford SVT Raptor 21 October 30th, 2009 08:27 AM
found
