Quantcast towing question - Ford Truck Club Forum
Old August 2nd, 2011, 11:57 AM
truckin's Avatar
truckin truckin is offline
Default towing question
Hello, new to forum, and have a question to ask.
I purchased my first truck , 2010 f150 supercrew 4x4 xlt xtr last year and had no need to tow anything at that time. Now, I have a need and wish to hook up a tent trailer. I have found that the stock rear bumper already has a ball hitch hole in the center of the bumper, just waiting for me to attach a ball hitch. The wiring assembly is also already to go.
Is there a problem with me simply attaching a ball hitch to the existing hole in the bumper and towing the tent trailer without me having to go and buying a full tow package?? the trailer is less than 5000 lbs.
The bumper reads the following message which is not quite clear to me
"Maximum tongue load 500 lbs, Maximum gross trailer weight 5000 lbs. Bumper capacity only, vehicle capacity may differ"
Old August 2nd, 2011, 01:53 PM
DoubleDee's Avatar
Images: 669
Howdy truckin' and welcome to the family!
No problem stickin' a ball on the bumper and towing that way.
What the statement on the bumper means, is that the bumper can only support so much weight before damage will occur. The bumper is attached to the frame rails by 6 small bolts, whereas the factory hitch that I have is attached via 6 large bolts. So, the bumper will only hold so much weight.
Tongue load is figured at anywhere from 10%-15% of the trailers weight. This tongue load will also be part of your payload weight. Payload weight is the trucks curb weight subtracted from the vehicle gross weight rating. And the gross combined weight rating is the never exceed number for the weight of the truck and trailer combined.
So to explain the bumper capacity only/vehicle capacity difference, we'll use my truck as an example.
GVWR= 6900
Payload = 1378
GCWR = 12200
Max trailer wt = 6600
And I have the same notice on my bumper, 500 tongue/5000 trailer.
My truck can actually pull a 6600 lb trailer, whereas the bumper can only pull 5000 lbs. It's all about the safety. Plus if you put more weight on that bumper than what it says, you'll get that sagging bumper syndrome.
Hope this helps.
Double(. Y .)Dee
SSG, TXARNG
How To Use The FTC Gallery
VIN Decoder
Big 3 Upgrade
Seat Removal
Interior Trim/Carpet Removal
Old August 2nd, 2011, 08:44 PM
whitesleeper's Avatar
Default The tow
as double dee said is all true and very well broken down ...
for what its worth here is my 2 cents worth to add to his 5.00 dollars worth . If you are going to be towing the camper very often or for any great distance i would put a class 3 hitch on the truck about 150.00 bucks for hitch insert pin clip and 2 inch ball carry out price OR go find a local junkyard and get the hitch and maybe the bolts for 30-40 bucks . THe gain from putting a hitch on is better weight dist on the truck and it will handle the trailer better . thats my 2 cents worth
enjoy
Old August 3rd, 2011, 01:34 AM
Images: 622
Liked 182 Times in 164 Posts
Hay truckin, check out the height of that bumper hitch
it could be too high and cause the trailer to not ride level
I like a receiver hitch attached to the frame
with this setup you can find the correct ride height by choosing a proper ball mount
they are sold in differant drop lenghts and can be inverted to suit your needs
plus I think a receiver hitch is safer
If you live close to North Georgia I have several receiver hitches for Fords that are collecting dust
let me know or go get one; around here its easy to find a 'CURT' or 'DRAW-TITE'
check your phone book or as 'sleeper' said junk yard
I can put one on myself useing a floor jack, both arms and a leg, but its easier with a helper
good run down on the info, DoubleDee
Old August 4th, 2011, 11:57 PM
Images: 243
Liked 34 Times in 33 Posts
Excellent breakdown Double Dee.I would also agree with Whitesleeper and Jsoko on the receiver hitch.Much better weight distribution and height adjustment.Also with the higher class 3 hitch you will be prepared to tow most anything ,and i keep an assortment of different size balls so that i am ready for anything that comes up Thats my pennies worth.
Old August 5th, 2011, 05:52 AM
pete59edsel's Avatar
Images: 101
Liked 6 Times in 6 Posts
I have nothing, day late and a dollar short....these guys nailed it!!
Old August 30th, 2011, 10:29 PM
jpelington's Avatar
jpelington jpelington is offline
I like a receiver hitches attached to the frame
i like the receiver hitch that can be inverted easily. even fords brands like that hitch deserve to be the best! way to go for ford
thumbs up!
james
(View-All Members who have read this thread : 29
ASwaff400 , caribvet , colorcrop , craw68 , DeuceDriver , DoubleDee , ecoboost68 , elec_inst , gvfc2 , HawaiianF150 , jpelington , JSoko , Klitch , machineman8625 , maddawg99 , muerte , nitrobreath , nytebyrd , pete59edsel , Pibster , Russo2 , screwon23s , skatebowd , Smoke Walker , t3ob17 , TheAmplified42 , timmjaxx , truckin , whitesleeper
Trailer Towing and Modification [S5 Ep.7-1] Gearz Gearz 0 June 2nd, 2011 09:30 PM
ASwaff's Towing Guide: Before You Leave... ASwaff400 Garage Talk: Shop Class 101 0 September 13th, 2010 01:51 PM
Question about E250 towing Hummer Ford Vans 5 July 16th, 2010 09:57 AM
question , towing
