Quantcast what would make a transmission mount break in half - Ford Truck Club Forum
Old September 23rd, 2011, 01:02 AM
BigTrouble's Avatar
BigTrouble BigTrouble is offline
Default what would make a transmission mount break in half
I changed my transmission mount today and the one that was on the truck was broken in half. I'll try and get some pic up on here later so we can figure out what went wrong or what happen to it. My truck is a 94 f150 4x4 Off Road
Old September 23rd, 2011, 04:32 AM
Images: 622
Liked 182 Times in 164 Posts
a variaty of things, remember the mount is there to take up the shock & torque of the drive train
The most common reason is aging and use. The rubber is susceptible to dry rot from the constant temperature changes. This process normally takes many years. The combination of temperature changes and the stress put on the mounts when ya put the vehicle in gear or take off from a stop wears the rubber out.
Also:
oil
rough terrain/speed bumps
heavy acceleration
heat & old age
Old September 23rd, 2011, 11:36 AM
whitesleeper's Avatar
Default broke
good post JSoko ..
You might want to check the motor mounts also . i have seen those break and inturn it breaks the trans mount .
Old September 23rd, 2011, 05:40 PM
BigTrouble's Avatar
I will check them. I know the rubber wears out after years of use, I also know that if well maintained the will last longer that the truck itself.
Old September 23rd, 2011, 09:39 PM
Images: 622
Talking Wtf
the last thing on anybodys mind is taking care of mounts LOL
and who in the hell maintains them
when the time is up its up
kinda like ball joints & u-joints just ask 'Towelie'
Old September 24th, 2011, 01:06 AM
BigTrouble - just curious, did you have to change out all of the motor and trans mounts?
Old September 26th, 2011, 07:58 PM
BigTrouble's Avatar
still haven't looked at the motor mounts had the Alabama Arkansas game sat and the race sunday will be checking them soon. I did replace the transmission mount
Old September 26th, 2011, 07:59 PM
BigTrouble's Avatar
And jsoko your right on that
Old September 26th, 2011, 08:17 PM
I never checked my transmission mount until the day I noticed that at full throttle my transmission rotated enough to put the stick from normal first gear position to past where 5th would be, far right that is, when I checked the bolts had worked their way loose to the point of almost falling off.
Whos truck is your avatar picture bigtrouble?
Old September 26th, 2011, 08:33 PM
when i pulled my old 302, the mounts where shot, one actually fell off when i got the engine on the lift... new mounts went on when i swapped the 351
ajames1463 , ASwaff400 , BigTrouble , DoubleDee , F150GT , HawaiianF150 , JSoko , Klitch , michaelsnodgrass18 , Russo2 , sbellinghausen , whitesleeper
Body mount sag. Russo2 1973-1991 Ford F150
11 June 29th, 2011 10:16 AM
High Lift Mount Locations (Photos) Joe'Bronco Garage Talk: The Tool Depot™ 0 May 31st, 2011 02:24 AM
How To Break-in That New Truck JSoko Garage Talk: Shop Class 101 1 April 7th, 2011 05:36 PM
Dana 44 - Operation Break Down - Completed nine5flareside Garage Talk: Solid Axle Swaps 35 February 10th, 2010 08:28 PM
Shallow mount subs LilBit 4x4 Garage Talk: Sound & Security 12 August 11th, 2009 07:22 PM
break , half , make , mount , transmission
