Quantcast Timing chain issue - Page 3 - Ford Truck Club Forum
  #21
Old March 23rd, 2012, 03:09 AM
At 250k, I'd smile if you have good compression and fresh chains/guides/tensioners. Cant go wrong with freshening that end of the motor up BEFORE catastrophe.
  #22
Old March 23rd, 2012, 12:02 PM
good point klitch
I would be curious what his compression is at over 250,000 miles
  #23
Old March 23rd, 2012, 12:58 PM
I bet a little low, probably due for a valve job, but if she isn't smoking maybe it'll last a while
  #24
Old March 23rd, 2012, 05:06 PM
I'd like to see some #'s just for the heck of it
you can get a decent screw-in compression tested at Advance for about $25
but I think it would be near impossible to screw it down the spark plug opening and get a good seat on the o-ring
  #25
Old April 11th, 2012, 06:36 PM
Thumbs up
Originally Posted by JSoko View Post
good point klitch
Hey guys,sorry it has taken so long. I have barley had time to do site votes in the last month.I have had to days off in three weeks but on one of those days i had Tim "racin bud from down the street" check compression on Big Green. All 8 Cylinders were around 150 Lbs he used computer engine analyzer.
  #26
Old April 12th, 2012, 08:59 AM
thats a good number
and I'm surprised its that high
if I had to take a random guess from a list of numbers, I would have said 137#
  #27
Old April 12th, 2012, 01:25 PM
Anyone got a how to for checking compression/ cylinder pressure whatever you call it?
Old April 12th, 2012, 09:53 PM
yes
look up Advance Auto, they got a compression tester for about $28
comes with all the different adaptors
1
Remove the plug wire from one of the cylinders. If you can't pull it off by hand, use the spark plug wire pliers. Pull the coil wire off the coil tower. Work the cylinders in order, so you don't forget which ones you've checked. Remove the spark plug, using the spark plug socket.
2
Screw the compression gauge into the spark plug hole. Press the button the side of the gauge to make sure the gauge is zeroed out. Have a helper crank the engine over five times. Write down the compression, which is measure in p.s.i.
3
Repeat for the rest of the cylinders; then Reinstall the plugs and the wires
  #29
Old April 12th, 2012, 10:03 PM
My dad has the gauge, just didn't know exactly how to do it, and it's exactly how I thought haha.
Thanks joey.
Old April 12th, 2012, 10:26 PM
make sure the o-ring seats but dont over tighten it
do not push gas pedal
do them all before you put the plugs back in makes it easier on the battery
and will prevent a possible fouled plug
now there are other things to do to figuer out if you have a bad valve or bad rings
you need to look that up
as I cant remember the sequence
ASwaff400 , BigBlue79 , BigT67 , Booba5185 , DoubleDee , f150man , GunSlingR69 , HawaiianF150 , JSoko , Klitch , losingmyhair , mikeg , MiracleMax , ONELOWF , Ridgerunner , Russo2 , skatebowd , swil73 , whitesleeper , wip
2004 Ford F150 VCT solenoid { Variable Cam Timing| Replacement...With Pics.! pete59edsel 2004-2008 Ford F150
52 December 26th, 2013 08:03 PM
Flooding issue BigBlue79 1973-1991 Ford F150
26 October 17th, 2011 02:36 PM
Timing Belts and Wiring Diagrams HawaiianF150 Garage Talk: Shop Class 101 0 September 6th, 2010 01:58 PM
Tonya Turk of So-Al Racing at the Loring Timing Association Hot Rod Magazine Hot Rod TV 0 August 19th, 2010 12:49 AM
Loring Timing Association Land Speed Racing Hot Rod Magazine Hot Rod TV 0 August 18th, 2010 06:57 PM
chain , issue , timing
