Quantcast Bolting on Torque Converter???? - Page 2 - Ford Truck Club Forum
Old October 28th, 2012, 03:53 PM
Originally Posted by Booba5185 View Post
J pretty much got this one, but the torque converter holds a LOT more than a quart. I'd have a gallon or 2 on hand to fill it back up. Start it, run it for a few seconds, then check the tranny fluid, it'll be low. Fill it back up, then hold the brake and shit through all the gears, (1-2-D-(D)-N-R-P) then put it in neutral and check the fluid. Repeat until it stays at the lower side of the full mark. Then drive her around the block a few times (squealing like a happy school girl at your success because you can drive your truck again) to actually warm the tranny up, then check the fluid again. What transmission do you have in there?
Blasphemer, how is that possible?!?!?!?
Old October 28th, 2012, 04:04 PM
Oh yea you can, you just have to flush afterwards, lol.
Old November 3rd, 2012, 09:33 PM
adoporto's Avatar
adoporto adoporto is offline
How do I find out what kind of tranny I have?
Old November 3rd, 2012, 09:36 PM
In my signature there is a link to door tag codes, there should also be a picture in that thread showing you the different pan patterns determining the transmission
Old November 3rd, 2012, 11:23 PM
Should be an E40D. You should have a push button OD switch. Since you were asking about a torque converter I know you have an automatic, and in 1993 99% of automatics were E40Ds. There is a SLIGHT possibility that you have an AOD, but you won't have an Overdrive switch then. Also, if you have an AOD the gear indicator will be PRN(D)D1 and an E40D is PRN(D)21.
Old November 5th, 2012, 02:59 PM
Images: 622
Liked 182 Times in 164 Posts
I vote for E4OD
90f150xltcenturion , adoporto , ASwaff400 , BigBlue79 , Booba5185 , catmechanic07 , Herbie , JSoko , rikard , Russo2 , The Frankster , yahnke
Useing a Torque Wrench JSoko Garage Talk: The Tool Depot™ 2 August 22nd, 2012 09:15 PM
Catalytic converter question willys5555 Garage Talk: Engine & Drivetrain 7 June 12th, 2010 08:53 AM
tranny/torque converter ? nflfreak43 1992-1996 Ford F150
10 March 14th, 2010 12:03 PM
Torque Converter and Cams HELP? nine5flareside 1992-1996 Ford F150
10 August 27th, 2009 07:55 AM
?Torque Wrench & Extensions ? JSoko Garage Talk: The Tool Depot™ 18 July 12th, 2009 10:01 PM
bolting , converter , torque
