Quantcast 1992 F250 Engine swap - Ford Truck Club Forum
Old January 16th, 2013, 10:26 PM
tdem630's Avatar
tdem630 tdem630 is offline
Default 1992 F250 Engine swap
I currently have a 7.3 diesel in the truck and it has piston slap at 266,000 miles. I am looking to put either a 5.8 or 460 V8 into the truck to replace the 7.3. Has anyone done this type of swap and if so, what will I run into when I am doing it. It has the E40D automatic transmission too. Not sure if the bellhousing is the same for the gas engines.
Old January 16th, 2013, 11:22 PM
Diesel and gas engines DO NOT share the same bellhousing, and IIRC the E4OD between the two aren't the same, the Diesels are more beefier for all the torque the Diesel makes.
I haven't done the swap personally but maybe someone else here with more knowledge has.
Old January 17th, 2013, 12:06 AM
Go pick up another diesel or a whole different truck if you aren't attached to this one for any reason. Until you change over the whole fuel system, trans, wiring, computer (that your diesel lacks and the gas truck needs) and have the actual engine itself, you'd be way ahead finding a lowermile 7.3 to put in. Heck you'd be further ahead finding a 7.3 powerstroke to put in, it's less wiring that a gas truck.
Old February 23rd, 2013, 05:58 PM
Lostin90s's Avatar
The 7.3 and 460 Do share trans . quickest way to go is donor truck with all things needed . Harness its a quick swap .Harness ecu in engine bay . I just drop tanks and have them clean do pumps and lines good to go . You have motor out any way trans is just few more things to unhook .
Yes its more in depth than that there is things to be addressed but a well built 460 is cheaper to do and up keep and if you dont haul all time will move your truck fine . if you have all parts on hand And time to do it . no biggie.
Old February 24th, 2013, 12:23 AM
They share a trans and the bell housing is even the same size, but the bolt pattern is not the same.
Old February 24th, 2013, 02:15 PM
catmechanic07's Avatar
Images: 25
Liked 14 Times in 14 Posts
For the time to do all this and parts, id think youd be better off overhauling the 7.3 you currently have. What exactly are you talking about with "piston slap"? slapping the valves, slapping the block, the cylinder, the connecting rod on crank??? I overhaul diesels and have actually done a 7.3....its not a bad job if you have a manual and tools/time. Is it a turbo or just plain jane 7.3?
Black Sheep of FTC
5.0_250 , ASwaff400 , BigBlue79 , Bluegillfisher , blueoval92 , Booba5185 , catmechanic07 , Dave8N in Pa , frank5079 , harrison28 , Jasons8166 , JSoko , Lostin90s , michaelsnodgrass18 , Russo2 , SlydinClyde , tdem630 , utanapishtim1988 , Wolfe
1992 ford f150 5.0 engine wont start tommie641 1992-1996 Ford F150
12 October 19th, 2012 10:36 AM
460 engine swap farmall Garage Talk: Engine & Drivetrain 7 June 5th, 2012 09:22 AM
engine swap 460 Dream 1992-1997 Ford F250 | F350
6 March 1st, 2012 09:40 PM
300 I6 Engine swap BigBlue79 Garage Talk: Engine & Drivetrain 29 January 10th, 2012 11:42 PM
1992 , engine , f250 , swap
