Quantcast Transmission question - Ford Truck Club Forum
Old March 6th, 2013, 08:19 PM
cotton's Avatar
cotton cotton is offline
Images: 2
Default Transmission question
I have a 1985 F-150 XL Explorer. It has the 300 (4.9). Im not sure what type transmission I have. The numbers are rf-e2tp-7006-aa.
Old March 6th, 2013, 08:22 PM
nflfreak43's Avatar
nflfreak43 nflfreak43 is offline
is it an automatic?? manual or what??
if an auto you have a choice between C6 or AOD.. C6 is more common..
Old March 6th, 2013, 08:31 PM
I'm gonna say C6 more than likely. Easiest way to ID is looking at the Transmission Pan:
Old March 6th, 2013, 08:55 PM
Nevermind. Blue's post does a much better job than I could at the moment. Odds are it is a C6 if it's an auto. If it's a standard than its most likely a T18 unless its the rare 3spd column shift.
Old March 6th, 2013, 09:10 PM
1983 was the Last Year for the Column Shift 3spd, used only in the F100's. They also used more New Process 435's behind the 300 in the 1980+ trucks then they did the T18. Not saying they didn't come with it, they were optioned, just more NP435's than the T18.
Old March 6th, 2013, 09:14 PM
Good info here. For future reference that transmission picture is in the door tags post linked in my signature.
Old March 6th, 2013, 09:16 PM
You can also look at the Shift indicator, as long as it's Auto, and the transmission hasn't been replaced with a different one.
C6: P R N D 2 1
AOD: P R N (D) D 1
C6 was used majorly behind the 300 cause of the 300's torque, before the 351w H.O. came out, the 300 had the 2bbl 351w beat in torque and almost the same horsepower, then after the H.O. the 351w had a little more of an edge in torque and horsepower.
Old March 6th, 2013, 09:19 PM
Also, AOD as long as it's stock transmission pan, will have "Ford Metric" stamped in it.
Old March 6th, 2013, 09:32 PM
cotton's Avatar
Images: 2
I know the trans in not original. Looking at Bigblue79's post its a c4. Thank for all the every one. Now all I to do is trry to find a cheap used 4 or 5 spead auto, so I drive at higher speeds.
Old March 6th, 2013, 09:36 PM
That one was replaced then.. They didn't offer the C4 with the 300 in the 1980's.
AFAIK, they're isn't a 5spd Auto made to bolt up to the Windsor pattern that is Vacuum/Hydraulic operated. You'll have to find either a C6, or an AOD from a Carbureted truck, the EFI's used a TV cable to shift them. Or if your mechanically inclined, consider a M5OD or ZF-S542 swap, both are 5spds, the ZF is beefier and has a Granny Gear for 1st with OD for 5th.
ASwaff400 , BigAlum , BigBlue79 , bikertrash3531 , Booba5185 , cotton , FXRS , glc , ilovefords31 , JSoko , Kaotik , nflfreak43 , Russo2 , Scorekeeper58 , stro , Web Foot
55 223 six od Transmission John Lightcap 1948-1983 Ford F100
2 October 14th, 2012 10:23 AM
transmission little dave 1973-1991 Ford F150
10 July 31st, 2012 08:14 PM
E4OD 2wd Transmission bikertrash3531 Auto Parts For Sale
0 July 20th, 2012 09:33 PM
auto transmission joseywales 1948-1986 Ford F250 | F350
9 June 27th, 2012 12:49 AM
f150 transmission bobmc 4x4 1992-1996 Ford F150
3 November 14th, 2011 05:54 PM
question , transmission
