Quantcast Rough Idle, No power, black smoke??? - Page 2 - Ford Truck Club Forum
Old January 1st, 2014, 01:35 PM
adoporto's Avatar
adoporto adoporto is offline
Thanks BT, I did get a new fuel pressure regulator and no change. As for PIP I'm going to have to read up on this not sure what that is.
After letting the truck sit for a few days it did start fine and ran fine, until I got home and was sitting in it and out of no where it started doing it again.
I turned off truck and sure enough the problem was back, when I turned the key on the fuel pump wouldn't stop and was rough getting started again.
I was talking to a buddy and he said it could be a bad EEC or ECM? I guess this is the CPU and it tells the primer when to stop? Makes sense just would like more evidence before I go spend $150 plus bucks.
Before I do that I am considering just for the heck of it replacing fuel pump relay and TPS. Which seem to fix a lot of problems I have read on here. I will be updating soon. Thanks
1992 F150 XLT 4x4- 1995 donor motor 5.0/302
Mods: K & N intake, MSD ignition, Reroute PCV, Rubber Vacuum System, and Remote Start
Soon to come: Long tube Headman Headers
Old January 13th, 2014, 03:30 PM
adoporto's Avatar
Default Case closed, I hope!
So I finally pulled the ECM on my truck and opened it up. It wasn't very obvious at first looking, so I carefully pushed a couple of the capacitors to the side and what do ya know one of them had burned a lead off to where it wasn't making contact. Another one looked a little questionable.
So with some help from Youtube I found a guy who actually had the same problem and he shows how to replace the capacitors. (Ford OBD-1 ECM Capacitor Replacement 1992 F-150)
I am postive this is the problem, but won't know until I put the ECM back in today.
Will probably replace the ECM eventually but this will work for now.
Old January 13th, 2014, 05:20 PM
Images: 622
Liked 182 Times in 164 Posts
good info
thanks for sharing
Old January 13th, 2014, 06:06 PM
adoporto's Avatar
Exclamation Codes?
Yup, one thing I forgot to mention was that when the primer wouldn't stop I couldn't get any codes.
So when the fuel pump primes and continues to do so, it will start but run like crap. I would first check the fuel pump relay then ECM.
I priced ECM at O'Reilly's and the guys said $100 to $150 depending on which ECM I had.
The Capacitors were like $1, the one I needed came in a assortment so i ended up paying $7 for the whole bag even though I just needed that one. Oh well lots cheaper than $100!
Old January 13th, 2014, 06:24 PM
Man, that's a good piece of info!!! I would have never thought to have opened up the ECM to take a look. I would have just bought another one.
Old January 13th, 2014, 06:51 PM
adoporto's Avatar
Ya, if I didn't want the for football squares I would have just bought a new one!
  #17
Old January 13th, 2014, 08:08 PM
Lol. I don't blame ya there.��
  #18
Old January 13th, 2014, 11:41 PM
Images: 243
Liked 34 Times in 33 Posts
adoporto , BigBlue79 , bikertrash3531 , Booba5185 , Buford , DDByers , F150GT , glc , Herbie , JSoko , Klitch , lanejesse85 , mike watson , Old red and white , polargeek , Russo2 , seschenburg , skatebowd , The Frankster , warodgers
5.4L 3V with miss, rough idle and codes P0340, P0344, P0345, and P0349 lindboep 2004-2008 Ford F150
8 August 18th, 2014 07:09 PM
High Idle to low idle dead spot Lostin90s 1992-1996 Ford F150
3 March 15th, 2013 09:45 PM
Hard start rough running Russo2 1973-1991 Ford F150
27 December 21st, 2012 07:48 AM
16 August 26th, 2012 10:44 AM
Diagnostic Smoke. Klitch Garage Talk: The Tool Depot™ 2 January 31st, 2010 09:04 PM
black , idle , power , rough , smoke
