Quantcast starting issues - Ford Truck Club Forum
Old December 22nd, 2013, 09:04 AM
rollinblacksmoke's Avatar
rollinblacksmoke rollinblacksmoke is offline
Default starting issues
ok guys, i have a 79 f-250 crew cab 4x4, with a 400 engine, and a c-6 transmission. when i turn the key to the on or run position, the starter spins, and the engine fires. the problem is that the starter stays engaged, and won't disengage unless i turn the key off. this is a new wiring harness with everything connected correctly according to the directions. it has a new starter(from napa), and another new solenoid (this one from autozone..the most expensive one they had). anyone have any ideas? i can't wait to get this thing back on the road!!!!!!!! thank you for any help.
Old December 22nd, 2013, 09:37 AM
Images: 622
Liked 182 Times in 164 Posts
well the solenoid actuates the starter so do you have a bad solenoid
or incorrect wiring from the harness replacement
there's a way to check this with a multimeter but I don't know how
not many folks on the site lately, hopefully one will chime in with an answer
there are several that know this problem
Old December 22nd, 2013, 09:54 AM
again, thank you sir! i have checked everything that i can think of. i am no electrical professional, but i do know my way around a digital multimeter, and have ohmed out, and checked a LOT, but i just haven't figured it out yet. i will get it just don't know which simple thing that im overlooking. thank you again for the response, and the help on the pics!
Old December 22nd, 2013, 05:09 PM
Images: 622
any body ???
Old December 22nd, 2013, 06:01 PM
I had an 81 Crown Vic that did the same thing. It was the ignition cylinder. I always had to turn the key slightly backwards to disengage the starter. I replaced it and all was well.
Old December 23rd, 2013, 08:16 AM
thanks, bikertrash, did that switch "feel" sticky, or grinding or anything out of the ordinary, as i suspect mine at this point, but it feels fine. it doesn"t bind, stick, drag or anything
Old December 23rd, 2013, 09:47 AM
No, it didn't bind or anything, was just wore out enough it made constant contact until I moved it back slightly.
Old December 23rd, 2013, 09:34 PM
good deal. i will try that and a couple other ideas. will probably be sometime after
Christmas before i have a chance to work on it again, but i can't wait to have that puppy running again!!!!!!
Old December 24th, 2013, 12:52 AM
Being without your ride sucks!!! I know a little too much about that!! Lol.
Old December 24th, 2013, 09:33 AM
i have other trucks, but i LOVE these old
fords. my first was a 77 f-150, and i just cant wait to get this one back out on the road, but then it'll be the next upgrade/project, till i eventually get it where i want it.
bigcreek , bikertrash3531 , catmechanic07 , glc , JSoko , Michaelbsr1967 , RANGERDICK , rollinblacksmoke , skatebowd , Strokin Power , Wyofordguy
Starting A New Job JSoko General Discussion
6 April 5th, 2013 12:36 PM
Starting Problems Sekyridgerunner 1992-1996 Ford F150
7 October 17th, 2012 05:36 PM
94 Bronco starting problems sellerskyle 1992-1996 Ford Bronco
7 November 16th, 2010 03:50 PM
issues , starting
