Quantcast Slave Cylinder Spacing - Ford Truck Club Forum
Ford Truck Club Forum > GARAGE TALK > Garage Talk: Engine & Drivetrain
Old March 8th, 2019, 02:39 PM
Default Slave Cylinder Spacing
So on my M5R2, the clutch is a little soft. By the time the clutch fully engages the pedal is on the floor. I've been driving it this way, but I know once it gets some wear on it, it's gonna start grinding while shifting. Will there be an issue if I put some washers behind the slave? I'm thinking this will give me more "meaningful" travel with my pedal. Thoughts?
Old March 8th, 2019, 03:00 PM
Is your slave internal or external?
Old March 8th, 2019, 04:32 PM
Internal. Hydraulic. I forgot to mention that.
Old March 8th, 2019, 05:18 PM
The only adjustments you can do are at the pedal and the master cylinder. Have you tried reverse or power bleeding it?
Old March 8th, 2019, 11:47 PM
I did bleed it after install. The push for on the master wasn't adjustable best I remember. I'll check tomorrow though. Right now I have about 1/3 pedal that does nothing. And the rest is real soft engagement until the floor.
Old March 9th, 2019, 12:27 AM
The pushrod is not adjustable, but you should be able to rig something up at the pedal end. You may need to either power bleed it or reverse bleed it.
Old March 11th, 2019, 08:31 AM
Gotcha. I didn't get the opportunity to mess with it this past weekend. I'll see if the local O'Reily's has a power bleeder I can rent. I did try the reverse bleed originally, but couldn't get a good enough seal around the bleeder valve to keep it from leaking, so we did it the old fashioned way, which obviously wasn't quite good enough.
(View-All Members who have read this thread : 2
glc , harrison28
clutch slave harrison28 Garage Talk: Engine & Drivetrain 1 March 25th, 2016 06:26 AM
Detailed guide on changing clutch slave cylinder? XLTAlex 1992-1996 Ford F150
1 November 9th, 2015 08:38 AM
How much would it cost to have the slave cylinder in a clutch changed.. XLTAlex 1992-1996 Ford F150
10 August 11th, 2015 02:17 PM
Leaking clutch slave cylinder XLTAlex 1992-1996 Ford F150
2 June 24th, 2015 03:07 AM
'95 F250 4x4 slave cylinder issues... 1977 F-250 4x4 Custom 1992-1997 Ford F250 | F350
3 January 6th, 2013 11:14 AM
cylinder , slave , spacing
