Quantcast Fault Codes OBD,DTC - Ford Truck Club Forum
Old December 6th, 2014, 05:36 AM
igor2009's Avatar
igor2009 igor2009 is offline
Default Fault Codes OBD,DTC
More HERE
Fault Code Probable Fault Location Possible Cause
B1213 Immobilizer - number of programmed keys below minimum limit Program additional key(s)
B1232 Immobilizer read coil - not connected Wiring, immobilizer read coil
B1342 Engine control module (ECM) ECM
B1600 Immobilizer - transponder signal not received Incorrect/damaged key, wiring, immobilizer read coil
B1601 Immobilizer - incorrect transponder signal Incorrect/damaged key, incorrectly programmed, wiring, immobilizer read coil
B1602 Immobilizer - incorrect transponder signal Incorrect/damaged key, incorrectly programmed, wiring, immobilizer read coil
B1681 Immobilizer read coil - signal not received Wiring, immobilizer read coil
B2103 Immobilizer read coil - not connected Multi-plug connector disconnected, poor connection, wiring, immobilizer read coil
B2139 Immobilizer - PATS signal not recognized Incorrectly programmed
B2141 Immobilizer - ECM data not transferred Incorrectly programmed
B2431 Immobilizer - transponder programming malfunction Incorrectly programmed
C1160 Transfer box - control circuit malfunction -
C1728 Transfer box, variant selection - 2H/4H Wiring, transfer box control module, transfer box range selection motor
C1729 Transfer box, variant selection - 4H/4L Wiring, transfer box control module, transfer box range selection motor
C1970 4WD, 4x4 low range switch - short circuit to positive Wiring, transmission range (TR) switch
C1971 4WD, 4x4 low range switch - circuit malfunction Wiring, transmission range (TR) switch
C1979 Four wheel drive hub lock solenoid - circuit malfunction Wiring, four wheel drive hub lock solenoid, hoses blocked/leaking
C1980 Four wheel drive hub lock solenoid - circuit malfunction Wiring, four wheel drive hub lock solenoid, hoses blocked/leaking
P0, P2, P34xx, U0, U3, Failure type Refer to EOBD trouble code table -
P0167 Fuel timing error (1,8 D) Wiring, CKP sensor, injector needle lift sensor, fuel injection pump, fuel injection pump control module, ECM
glc , igor2009 , mr wu , Russo2
Codes bikertrash3531 1992-1996 Ford F150
13 May 7th, 2013 10:07 AM
codes/no codes joe250 1987-1991 Ford F250 | F350
3 March 23rd, 2013 10:32 AM
Codes! JCruz 1973-1991 Ford F150
3 January 29th, 2013 10:50 PM
Door tag codes. Russo2 Garage Talk: Shop Class 101 2 February 28th, 2012 09:54 PM
Trans codes Klitch 1997-2003 Ford F150
3 October 20th, 2011 03:27 PM
codes , dtc , fault , obd
