Quantcast 1995 ford f150 4.9 fuel problem - Ford Truck Club Forum
Old January 10th, 2015, 09:45 PM
Josh_petrovich's Avatar
Josh_petrovich Josh_petrovich is offline
Default 1995 ford f150 4.9 fuel problem
When i first start the truck it will idle fine and drive fine for about a minute. Then it starts reving up and trying to die. It will die a couple times but once it warms up it will idle correctly but if i give it to much throttle it will bog down. It wont go over 50 and if i try to push it over 50 it will sputter. It does it on both tanks. Trying to figure what to start with. I have tried adding seafoam and i cleaned the throttle body real good. Any suggestions help! Thanks
Old January 11th, 2015, 12:07 AM
replace the fuel filter it's cheap and also a good place to start, I always cut mine open to see whats inside
but
"Then it starts reving up and trying to die" - I'll have to think about this
there may be an electrical part issue
or
the carb may have some crud in it
I was thinking fuel pump but I dont think it would cause the intermittent rev and bog down
wait and see what others say
Old January 11th, 2015, 12:25 AM
Ok man thanks. Im gunna replace filter and i have removed and cleaned the carb. Im probably gunna replace the fuel regulator. I dont think its the pumps either cause it does it on both tanks and i hear the pumps kick on unless it faulted and is dumping to much fuel to it.
Old January 11th, 2015, 10:55 AM
Carb on a 95???? That should be EFI.
Have you tried cleaning the IAC (idle air control)?
Are you sure you don't have a clogged cat?
Old January 11th, 2015, 10:58 AM
what glc said
I never think about EFI, came I think starting in 1987
clogged cat made a car I had run like crap
Old January 11th, 2015, 05:09 PM
Yea my bad guys i didnt even mean to say carb. I cleaned the throttle body and i have thought about the cats.
Old January 11th, 2015, 10:59 PM
Fuel filter first. Then fuel pressure. IAC wouldn't cause an issue off idle.
Pull codes as well. Post back with your findings and we will help you along.
Old January 12th, 2015, 06:06 PM
Ok thanks. There is one thing, i dont know how to pull codes. Can someone tell me how?
Old January 12th, 2015, 06:58 PM
it has something to do with turning the ignition off & on and counting the flashes
I did a site Search and could not find it
I'm sure someone will come on and direct you in the right direction
Old January 13th, 2015, 10:59 AM
How to pull codes, plus list:
http://www.troublecodes.net/ford/
adoporto , ASwaff400 , dkenny9 , Flareside95 , glc , Josh_petrovich , JSoko , judd94 , logix89 , Russo2 , Sclove ford , waterguy73
1995 4.9 fuel problem Josh_petrovich New Member Introductions 4 January 10th, 2015 11:58 PM
Fuel Delivery Problem jelarf 1992-1996 Ford F150
21 August 22nd, 2012 01:00 AM
1995 F150 Dead Fuel Pump nine5flareside 1992-1996 Ford F150
43 June 10th, 2012 02:11 AM
1995 , f150 , ford , fuel , problem
