Quantcast Code 327 help - Ford Truck Club Forum
Old February 2nd, 2015, 06:39 PM
chesster51's Avatar
chesster51 chesster51 is offline
Default Code 327 help
Check engine light comes on randomly and usually last about 3 - 5 seconds and then goes off. May stay off for several minutes but eventually does it again. Bought a reader and found code 327. I see that it is EGR related. I've only had the truck 2 months and see that it has a new EGR unit installed and was done at a shop a couple of months ago according to the service records that came with the truck. I've looked at the green vacuum line and it appears to be in good shape. What can I do to find what's causing the code?
Old February 2nd, 2015, 07:11 PM
have you checked all the sensors in the system
Old February 2nd, 2015, 07:26 PM
chesster51's Avatar
I used all the tests that the code reader was capable of performing. Which sensors should I be looking at and how are they checked?
Old February 2nd, 2015, 10:37 PM
http://easyautodiagnostics.com/ford/...e-egr-system-1
Old February 2nd, 2015, 11:44 PM
EGR feedback signal is/was low – EVR or PFE
What year and engine?
Old February 3rd, 2015, 12:17 AM
chesster51's Avatar
1994 5.0
Old February 3rd, 2015, 12:18 AM
chesster51's Avatar
Originally Posted by skatebowd View Post
That's a great article, thank you.
Old February 3rd, 2015, 12:28 PM
EVR = EGR Valve Vacuum Regulator Solenoid
PFE = DPFE Sensor (Delta Pressure Feedback Egr)
Note that the procedure Skate linked does not apply to a 94 F-150. However, the concept is similar. Rock Auto lists an EGR valve and a DPFE for your engine, but not a EVR.
Old February 3rd, 2015, 03:16 PM
chesster51's Avatar
The code only showed in the KOEO test, so I'll try clearing the code first to see if it comes back. If it does I' ll try further testing. I'd really like to pin point the problem so I can avoid changing parts that aren't bad.
Old February 3rd, 2015, 08:14 PM
Skate, do you mind if I add that link to a new thread
chesster51 , glc , Gongo , Hoosier , JSoko , lanejesse85 , Russo2 , skatebowd , vjsimone
help trouble code 171 & 172 rpez4u New Member Introductions 2 July 16th, 2014 08:37 AM
what is the paint code on a 93 f-150 knifeman 1992-1996 Ford F150
2 January 16th, 2014 08:53 PM
P0016 code bigfish21 2004-2008 Ford F150
2 August 25th, 2012 07:31 PM
1991 4.0 code 85 Klitch 1989-1992 Ford Ranger
0 March 20th, 2012 11:52 PM
P0022 Code pete59edsel 2004-2008 Ford F150
10 June 27th, 2010 03:06 PM
327 , code
