Quantcast 2000 4x4 limited - Page 2 - Ford Truck Club Forum
Ford Truck Club Forum > ALL OTHER FORD MODELS > Ford Excursion
Old July 1st, 2015, 10:15 AM
You are going to have fun trying to get the 5R110 working in place of the 4R100.
Old July 1st, 2015, 05:49 PM
hmmmmmmm good luck
Old July 2nd, 2015, 07:59 AM
finally had a moment to climb underneath it yesterday. it's leaking between the tranny and transfer case. so it may be just something as simple as a tail shaft seal. i've planned on grabbing the 05 set up and and axles anyway. rather see it in my little shop at my house then someone else's. i have the wiring harness for the 05 and a programmer for the computer. research i've done says the bell housing has the same bolt pattern. do you think the computer will except the change?
Old July 27th, 2015, 08:08 AM
i found the culprit to my troubles,.....leaking transfer case from vibration with the drive shaft. gonna replace the tail shaft seal on the tranny while i've got the transfer case out. picking up the drive shaft this afternoon. should have it and new transfer case back in it today. can't wait to get the beast back on the road.
Old July 31st, 2015, 10:32 AM
gwfan's Avatar
gwfan gwfan is offline
That's a lot of money. Share your build soon. That would be interesting.
Old July 31st, 2015, 11:07 AM
driveshaft only cost me $365 with new solid u-joints. tailshaft seal and gasket for transfer case only cost me about $22 together. new transfercase came with the other tranny i have. oh,....and $12 for the 12 pack i got at the gas station on the way home. i'll snap some photo's this weekend and post 'em.
  #17
Old August 14th, 2015, 12:05 PM
so i fell a little behind on my excursion repairs. but with school lurking right around the corner,...the pressure is on. i have the extension coupling off the back of the tranny. waiting on the Ford garage to get me the CORRECT gasket and seals so i can put it back together. new driveshaft looks good. got some new bolts for the drive shafts that are hex head instead of that starred, 12 point head that were stock. more photos to come.
Name:	extension coupling.jpg
ID:	1127   Click image for larger version
Name:	back of trany.jpg
  #18
Old August 14th, 2015, 09:14 PM
I had a bitch of a time getting those bolts out of a 8.8
broke 2
good luck on your repair
and with school
  #19
Old August 17th, 2015, 10:50 AM
it took me 3 different sockets to get them all out. once they were all out,..i threw them in the trash with many foul expletives during and following. i was ready to break out a torch about half way through.
  #20
Old August 18th, 2015, 10:00 AM
got 'er all back together last night. started around 5:30ish, finished around 8:45. thought i had a couple of jugs of tranny fluid laying around,...i only had 1. test drive will have to wait until after work this afternoon. garage tried to sell me another incorrect gasket. thankfully they had the right 1 on the shelf. posting a few photos of the extension housing and transmission support going back in. i'll take some more of the completed install with the new drive shaft and post them later on.
ID:	1129   Click image for larger version
ID:	1130   Click image for larger version
ID:	1131   Click image for larger version
ID:	1132   Click image for larger version
« just bought an ex | There is no next thread »
ASwaff400 , glc , gwfan , harrison28 , JSoko , Klitch , skatebowd
2000 F250 haunting Cothrom 1999-2007 Ford F250 | F350
3 March 5th, 2012 06:09 PM
Fathers 2000 PSD Klitch 1999-2007 Ford F250 | F350
6 November 15th, 2011 11:32 PM
How to Change the EGR on a 2000 Ford F-150 JSoko Garage Talk: Shop Class 101 0 July 15th, 2011 09:33 AM
2000 f150 3rd member * Terry G. 1997-2003 Ford F150
7 June 16th, 2011 08:55 AM
Limited sale on leupold scopes DoubleDee General Discussion
1 May 27th, 2011 05:27 PM
2000 , 4x4 , limited
