Quantcast Leaking clutch slave cylinder - Ford Truck Club Forum
Old May 29th, 2015, 05:56 AM
XLTAlex's Avatar
XLTAlex XLTAlex is offline
Post Leaking clutch slave cylinder
I can open up the inspection port and i see break fluid leaking from somewhere around the slave cylinder. it is a new clutch and it worked fine moving it to where it is now but it sat 9 months then started giving us trouble. could the seal just be dry? is there anyway to do anything without dropping the transmission?
Old May 29th, 2015, 10:32 AM
if it's leaking around the hose inlet, there is an o ring you can replace. maybe the bleeder valve isn't threaded in all the way. other then that,.......get a 12 pack and get your creeper and floor jack.
Old June 24th, 2015, 03:07 AM
gwfan's Avatar
gwfan gwfan is offline
It seems that the seals are already worn out. You may need to remove and replace clutch master cylinder and slave cylinder. Have it checked by a mechanic, just to be sure.
glc , gwfan , harrison28 , jsilva1987 , JSoko , ncranchero , skatebowd , XLTAlex
Clutch master cylinder brick13 1992-1996 Ford F150
8 August 31st, 2013 12:06 PM
'95 F250 4x4 slave cylinder issues... 1977 F-250 4x4 Custom 1992-1997 Ford F250 | F350
3 January 6th, 2013 11:14 AM
6 Speed Trans Leaking sbellinghausen 2009-2014 Ford F150
11 February 27th, 2012 06:54 PM
How to Fix a Leaking Sunroof JSoko Garage Talk: Shop Class 101 0 February 6th, 2012 09:50 PM
Tire Leaking Down ? May be the Rim JSoko Garage Talk: Shop Class 101 0 June 28th, 2010 01:10 PM
clutch , cylinder , leaking , slave
